Old 05-31-2007, 06:52 AM   #46
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
I must of missread the Nova web site a while back i sware the part numbers for the plus 5/7 blocks were different this was before the website change
but i just checked and they the same part numbers so durr lol
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 05-31-2007, 06:42 PM   #47
1 Xtreme R/C's Avatar
Trader Rating: 17 (100%+)
I have a plus 21-5 in my 8ight. Was at a big two day race last weekend, it wasn't running quite right, so I took it over to the local Novarossi sponsored guy, he fired it up and then promptly told my my crank bearings were about gone. I only have about two gallons through the engine. He said it was common in that engine, is this true? Anydody else have bearing issues with the 21-5? The local hobby shop on site didn't have the right size bearing, so I ended up buying a backup mill, and they will be puting new cermamics in my first engine and sending it to me.
1 Xtreme R/C is offline   Reply With Quote
Old 05-31-2007, 06:52 PM   #48
houston's Avatar
Trader Rating: 91 (100%+)
Talking
dude the plus 21-5 stock rear bearing absolutely sucks !!!!!! the best bearing i found to replace it with is the boca standard 9 ball 14.5 x 26 !! no slop and has been running killer for 2 gallons now !!! still not a bad idea to have extra engines as not to wear any one of them out too bad !! i have like 4 or 5 extra engines that are all a lil different and all run killer .
see ya at the showdown at the X ,
monty houston
the walla walla place is sweet !!!
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-31-2007, 08:24 PM   #49
Thanks Monty. I think Matt is putting TKO cermamics in it for me. He pulled my piston, sleeve, and carb off my old engine and put everything in the new mill so I didn't have to break in the new one. It ran perfect the rest of the weekend.
Old 05-31-2007, 08:28 PM   #50
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
I had the same issue with my 21-5 at about the 3 gallon mark.
Put TKO ceramics in and good as new.
It now has about 6 gallons on it and runs as strong as ever.
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
Old 05-31-2007, 10:55 PM   #51
houston's Avatar
Talking
the tko ceramics for the plus engines seem to be sloppy when they are new so i was very hesitant to use em !! might have just been bad batch , but i dont like to take chances !! thats cool that matt did that for ya man . props to matt !!
Old 06-01-2007, 04:30 AM   #52
RCRacing.com.au's Avatar
Well i just stripped my Plus 21-5T down this arvo and sure enough the front bearing seal is gone after 3&1/2 gallons.
The bearings have play in them now so i'll have to replace them both i'm guessing.
I thought i would check them before it got too late and lucky i did or it would have dusted my motor if i kept running it like that.
I was going to get TKO bearings but you think they aren't too good hey?
I have had Boca Bearings before and they shattered after 3 litres or less.
They were ceramic though so i was thinking of going steel again.
Houston the Boca ones you got, what is the part number and how much were they please?
The rest of the motor is perfect luckliy.
I also polished the brass sleeve and the top of the piston to get the black carbon off.
It should go hard once i replace the bearings.
I also have another one of these engines with about less than 2 gallons on it so i'll use it for a few litres then replace the bearings in it.
Next engine i get will be the AXE Rossi Mamba.
They go hard and are $325AU here so excellent value for money.
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 06-01-2007, 04:37 AM   #53
Turbine_au's Avatar
Would these be the bearings? http://www.amainhobbies.com/product_...oducts_id/7094
and:
http://www.amainhobbies.com/product_...oducts_id/2321
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 06-01-2007, 10:44 AM   #54
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
im running a P5X in a jammin X1CR and im very happy with the motor, but i just went and ordered a new novarossi 7 port turbo for a main, and gonna keep the P5X for a backup...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 06-01-2007, 02:55 PM   #55
I found a set of TKO Ceramics for $50AU delivered.
What do you think?
A-Main will want $35US shipping to send me 2 tiny bearings in an envelope.
Steve P
-Stuff for sale-
Old 06-01-2007, 06:22 PM   #56
houston's Avatar
Talking
ya those are the good bearings that i have been happy with in the plus engines !!! crappy bearings are not worth paying any money for . i have never had a problem with any tko bearing except for the 14.5x26 bearings . the boca bearings are great as long as they aren't the ceramic ones !!! good luck bro !!
later , monty
Old 06-01-2007, 07:48 PM   #57
Turbine_au's Avatar
$35US for shipping? I've gotten many quotes from them with a lot more stuff than two bearing and only just got to $30US shipping...
Are you sure that you weren't looking at the Fed EX prices as they are huge. The USPS down the bottom of the shipping prices are much better.
Old 06-01-2007, 07:49 PM   #58
What do you think?
Order from tko direct.Their shipping prices to the UK are great.
http://tkocompetitiondev.com/shop/index.php?cPath=38_41
LOSI 8IGHT 2.0 ALIGN SERVO'S, RB C5bb,RB C6 L2G,PICCO P7R EVO2,
ASSOCIATED RC8T, NOVAROSSI .28 8PORT, SAVOX SERVOS.
CRT.5 SH .12,
damo666 is offline   Reply With Quote
Old 06-01-2007, 11:43 PM   #59
Now i'm in 2 frames of mind about the bearings.
I've had one good set and one bad set of Boca Ceramics.
So i was thinking of going Steel again.
The Stainless ones look pretty good too.
hmmmm... what to do???
Steve P
-Stuff for sale-
Old 06-03-2007, 08:17 PM   #60
Id get the TKO ceramics for $50AU delivered
Futaba
Mugen
Novarossi
Byron's
Novarossi Plus 28-7 Engine Review Sylvain Nitro Off-Road 8 08-28-2008 12:08 AM
Novarossi N21B-2001BF Engine REVIEW Sylvain Nitro Off-Road 11 08-06-2008 06:25 AM
RB .12 R3 RC Review romuald31 Onroad Nitro Engine Zone 2 07-12-2008 01:21 PM
Novarossi NS12TSR1 engine review... Sylvain Nitro Off-Road 0 05-03-2008 07:22 AM
Ninja 12 MRT review romuald31 Onroad Nitro Engine Zone 5 11-21-2007 01:55 PM
