Old 05-30-2007, 07:39 AM   #31
Nitro$junkie's Avatar
Send a message via MSN to Nitro$junkie
Default Factory Settings
HSN Half a turn out from flush
LSN 2 and a half turns in from flush
If you want to make it run turbo plugs you need to just change the head button not the heat sink
You can get them here when they get more in stock
Futaba
Mugen
Novarossi
Byron's
http://www.hospitalrecords.com
Nitro$junkie is offline   Reply With Quote
Old 05-30-2007, 07:47 AM   #32
Turbine_au's Avatar
Ok, so those are the factory settings. So if I go a turn rich on the HSN and 1/2 a turn rich on the LSN, that'd be good for run in?
You beat me to the underhead, I just checked a-main and ta-da! http://www.amainhobbies.com/product_...oducts_id/4046
I had a look earlier but couldn't find it.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 05-30-2007, 07:50 AM   #33
it all depends on which run in method you choose theres alot of different ones
Futaba
Mugen
Novarossi
Byron's
Old 05-30-2007, 08:56 AM   #34
Turbine_au's Avatar
I'm going to go with the heat cycling method, similar to what someone mentioned on the first page of the thread.
Old 05-30-2007, 09:55 AM   #35
i heat cycled mine ive got about three gallons through mine the pinch is so tight you cant turn it over with a fly wheel on it... i never have trouble clearing jumps and never get motored down the stright.... i run the 7mm insert and an medium cold plug with 20%byrons.. the pipe i use is a jp3.. nad on good days i can get 7 almost 7and a half minutes... engine is real rich a 220,,, but as soon it hits 230-240its a monster
Garrison is offline   Reply With Quote
Old 05-30-2007, 12:58 PM   #36
freefallmarine's Avatar
This motor is great! I haven't got the 'K' version yet and was wondering if there was a big diffrence.
freefallmarine is offline   Reply With Quote
Old 05-30-2007, 01:48 PM   #37
the K uses the P/S from the P5
Futaba
Mugen
Novarossi
Byron's
Old 05-30-2007, 02:20 PM   #38
That's it? Just those 2 extra port's?..Cool..I have a 7 port p/s that i had for my p-5 wonder if that will work in my plus?
Old 05-30-2007, 05:50 PM   #39
houston's Avatar
Trader Rating: 91 (100%+)
Talking
the 21-5k uses an onroad style 7 port block that has seperate fuel diverters for vertical side ports and uses the standard p5 p/s with the r7 rod and has the drilled lightened head . the engine is a lil more efficient and even smoother than the 21-5 . one of the best engines of all time from nova is a plus 21-7t !!!! badass machine .
later, monty
oh and by the way all long stroke nova p/s sets will work in the plus series , 421b, 621b, 821b p/s sets are different though, longer stroke duration, smaller bore, 8 ports !!
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 05-30-2007, 07:48 PM   #40
Thank's for your help Houston!
Old 05-30-2007, 08:59 PM   #41
houston's Avatar
Talking
no prob bro , i know at least one or two things about novarossi engines !!
later, monty
Old 05-30-2007, 09:31 PM   #42
dose the p/s from the K fit in a 21-7
Futaba
Mugen
Novarossi
Byron's
Old 05-31-2007, 03:35 AM   #43
RCRacing.com.au's Avatar
I've put over 3 gallons (12 litres) through mine now and it still goes like a wild animal!
I found i had to run a hotter plug though after about 5-7 litres as it kept flaming out with a colder plug.
I put a C2TC in it and it is back to full noise and no problems.
I'm going to strip it down and check to see if it's ok inside.
I hope so.
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 05-31-2007, 06:23 AM   #44
houston's Avatar
Talking
the 21-7 is a standard plus block with a NOVAROSSI 7 PORT SLEEVE , THATS ALL . SO YES it will fit junkie !
Old 05-31-2007, 06:36 AM   #45
thanks houston
im not going rebuilding it i ended up geting a brand new JP for the same price as a rebuild kit
Futaba
Mugen
Novarossi
Byron's
Novarossi Plus 28-7 Engine Review Sylvain Nitro Off-Road 8 08-28-2008 12:08 AM
Novarossi N21B-2001BF Engine REVIEW Sylvain Nitro Off-Road 11 08-06-2008 06:25 AM
RB .12 R3 RC Review romuald31 Onroad Nitro Engine Zone 2 07-12-2008 01:21 PM
Novarossi NS12TSR1 engine review... Sylvain Nitro Off-Road 0 05-03-2008 07:22 AM
Ninja 12 MRT review romuald31 Onroad Nitro Engine Zone 5 11-21-2007 01:55 PM
