Old 01-04-2009, 07:52 PM   #211
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Originally Posted by houston View Post
call me i need to see which bearings you have , or just send me picks , if they are the sloppy 14.5x26mm bearings , do not install if you are sponsored by jim , get my number from him .
Is that issue still floating around?
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 01-04-2009, 08:24 PM   #212
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
I got one of the sloppy ones awhile back and didn't realize there was a problem. So I installed it and it ran fine for like 3 gallons. then i noticed it was making a bearing noise and was kinda gritty so i pulled it. Turns out some of the balls were cracked. luckily it didn't cause any harm to my engine. So I contacted TKO and they sent me a brand new one no questions asked. the one they sent was the new one. the way you can tell the difference is by the color of the balls(atleast in my experience). the earlier, bad ones had light grey colored ceramic balls where as the new good ones are a pearly black color. With the newer version you actually install them with the balls facing foreward(away from the backplate/counterweight side). The newer ones seem alot better. they have alot less slpo to begin with and the outer races are wider to protect the balls/cage better. I have several gallons on the new ones and they are perfect. SO BE WARE OF THE OLD ONES. AND WHEN INSTALLING THE NEW ONES MAKE SURE TO INSTALL THEM WITH BALLS FACING FOREWARD.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 01-04-2009, 08:58 PM   #213
ezveedub's Avatar
Was your bearing offset with the ball cage reversed. I had one which may have been TKO (got it from local modifier) and noticed this, so I remove the ball cage and reversed it so its like the OEM bearings (balls facing rear, cage facing front, offset towards rear, close to the crank)
Old 01-04-2009, 09:18 PM   #214
houston's Avatar
Trader Rating: 91 (100%+)
i am pretty peticular with my bearings i asked peter to send me new ones when he gets em made , i did get one plus bearing that was tight but it was too tight. couldnt hardly turn the crank with bearing installed until you heated up to about 250 . still find the boca stainless bearing in the rear and tko ceramic front bearing to be the ticket .
i only use the products i believe in , that way i am impartial and find only the best working products
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 01-04-2009, 09:35 PM   #215
ezveedub's Avatar
Thats what I had in it, a Boca rear and a ultra sealed Boca front. Just dropped a ceramic in, but I'll be watching it anyway.
Old 04-11-2009, 09:23 PM   #216
I just picked up one of the 21-5k motors and wanting to know the optimal setup in my 8ight buggy. My plans are... OD99 Plug, Dynamite 086 pipe, Novarossi short header. I am having issues deciding which restrictor to install and get the best fuel millage with this setup. On my old P5 I ran the 8 restrictor, wondering if the same results apply on this motor.
Jammin_Xtream49 is offline   Reply With Quote
Old 04-11-2009, 09:35 PM   #217
houston's Avatar
i wouldn't recommend the short header with the 086hs pipe , the stock header is perfect the rest is good , if you want a little better runtime go to 7mm restrictor . depending on your humidity level for plugs higher humidity cooler plug
Novarossi Plus 28-7 Engine Review Sylvain Nitro Off-Road 8 08-28-2008 12:08 AM
Novarossi N21B-2001BF Engine REVIEW Sylvain Nitro Off-Road 11 08-06-2008 06:25 AM
RB .12 R3 RC Review romuald31 Onroad Nitro Engine Zone 2 07-12-2008 01:21 PM
Novarossi NS12TSR1 engine review... Sylvain Nitro Off-Road 0 05-03-2008 07:22 AM
Ninja 12 MRT review romuald31 Onroad Nitro Engine Zone 5 11-21-2007 01:55 PM
