Old 12-06-2007, 07:37 AM   #181
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
Just make sure you heat the case evenly if you use a heatgun. In the oven, the case is completely heat soaked evenly.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 12-06-2007, 08:42 AM   #182
rabidsquirrel's Avatar
+1
rabidsquirrel is offline   Reply With Quote
Old 12-10-2007, 01:39 PM   #183
hi, have any of you guys ran the novarossi 9901 or 2006 pipe with your 21-5 engines yet and what results did you get with them?
rc007 is offline   Reply With Quote
Old 12-10-2007, 04:16 PM   #184
22Racer's Avatar
Trader Rating: 67 (100%+)
We have ran a Ofna 086, Rb 9886, and my son liked the 9901 best. He said it was the smoothest in the middle, Hottinger said it would be the best on fuel.
Rex
22Racer is offline   Reply With Quote
Old 12-11-2007, 05:46 AM   #185
Got to finally run my Hot Mods PLUS 21-5K in a race last weekend. I was wrapping up the break-in at the JConcepts Clash event in Lake Park, FL.
Motor was good! I think it is still coming into full power as I run it more, but so far, she's making good steam!
Temps in the 220~230F range, and idles great.
Using a JP-3 Pipe. Ambient temps were 70~88F throughout the day. Didn't really have to adjust it as the Ambient temps changed.
So far, it's a great motor in my book...
Old 12-13-2007, 04:05 AM   #186
GREGORY!'s Avatar
Default can i?
hi!i have a plus 21-5 and i must change the conrod.one shop near me has 2 conrods to choose from.the jp conrod {jp-07009}and the jp R6 light without the upper Bushing.Can i use any of these without promblems?and which is best?the light R6 last longer or not?
GREGORY! is offline   Reply With Quote
Old 12-16-2007, 12:42 PM   #187
ran the 2006 pipe today and it felt awsome!! strong although controllable bottom end with a good top end. Had 1/3 of a tank left after 6 mins of running. will try the 9901 next week.
Old 12-16-2007, 01:21 PM   #188
houston's Avatar
Trader Rating: 91 (100%+)
to use the rod without the bushing on the wrist pin side you will need the coated wrist pin that goes with it ! put a standard rod either r4 or r7 , dont use those axe rossi rods on ebay (JUNK!!!) . the r5 rods by novarossi seemed to be milled out too much on both sides , seen them snap 3 times (not in my engines) if you dont know what to do , you should let someone that knows a thing or two about engines replace the rod for ya , should check the wrist pin or just replace it while it is torn apart . if the rod is wore out , there is usually more wore out than just the rod !!! fyi
if you wanna send it to portland(LOL) with the parts(i can get parts also) and return shipping i will inspect and return the engine in the best it can be condition !!! pm me if interested
Houstons Engine Service
later , monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 12-22-2007, 11:35 AM   #189
GREGORY!'s Avatar
Thanks for your help houston!i have already buy the parts{a boca set bearings and a r7 rod}i have read that you have good performance with these bearings..now i have stuck in the direction of the rear bear.the boca bear is very close on the one side and i am afraid that i wiil have promblem with it if i put it with the close side look the carb...??{i have put it so the open side is looking the back plate}
Old 12-22-2007, 01:43 PM   #190
houston's Avatar
hopefully you pulled both seals off the bearing ? the side with the plastic cage goes towards the carb .
Old 01-01-2008, 04:32 PM   #191
Hi Monty,
You sent you a pm
cota348 is offline   Reply With Quote
Old 01-01-2008, 04:33 PM   #192
I meant "Just"
Finger check
Old 01-17-2008, 01:48 PM   #193
whats the difference between the novarossi 21-5 and the 21-5k?
Old 01-17-2008, 07:00 PM   #194
just picked up my ceo mod 21-5k - gonna be running nova 6 plugs, tilted green fuel, and dynamite 53 pipe pipe in my xt8 - looking forward to how it compares to my Max power M5 it is replacing!
gtsum is offline   Reply With Quote
Old 01-17-2008, 07:22 PM   #195
houston's Avatar
they changed the vertical transfer ports to the rear intake side of the sleeve instead of being toward the exhaust , added some fuel flow diverters into the case and also made the exhaust on the sleeve a little taller and less angle .
the plus 21-5 is basically a p5 with a plus style crank
monty
Novarossi Plus 28-7 Engine Review Sylvain Nitro Off-Road 8 08-28-2008 12:08 AM
Novarossi N21B-2001BF Engine REVIEW Sylvain Nitro Off-Road 11 08-06-2008 06:25 AM
RB .12 R3 RC Review romuald31 Onroad Nitro Engine Zone 2 07-12-2008 01:21 PM
Novarossi NS12TSR1 engine review... Sylvain Nitro Off-Road 0 05-03-2008 07:22 AM
Ninja 12 MRT review romuald31 Onroad Nitro Engine Zone 5 11-21-2007 01:55 PM
