Old 05-14-2006, 07:33 PM   #46
Default Long chassie conversion
Just picked up a long chassie kit for my S-3 and was just wondering, how long should the front and rear chassie braces be? The instructions are a little gray in this area. Any ideas would help, guessing can be a headache.
Old 4x4 is offline   Reply With Quote
Old 05-15-2006, 09:21 AM   #47
straydog's Avatar
Wow! I had to Buy it! RPM is moving to another class,
I'm hooked on my S3 so, his former Team TTR S3 Kit will stay within My Club!! R.C.R.E.
I think the one chassis is a Titan tech, @ 5mm thick,325mm wheel base.
The braces are in so the measure is tough to do, Rear Brace @ 120.2mm
top mounted to the Right, inside of forward wing mnt, bottom with @ 8mm deflection right of center.
Front Brace @ 75?mm btm mounted @ 10mm left of ctr.
Wow! these cars are sooo cool,
[ there is going to be a Racer L.S.T. 1 for sale]
Going to Go! Practice now,Race-Ya later
EB4S3/WS7II
Vendetta's ,C/F MLST
Mini Crawler
MRS4 Exo2 280/300 Spy
Bunch of o'l T-Maxx junkers
straydog is offline   Reply With Quote
Old 05-15-2006, 08:45 PM   #48
Mr-s413bt's Avatar
Hey guys.
Just wondering what u all think of the S3?? i am interested in getting one sometime soon
Glenn
Mr-s413bt is offline   Reply With Quote
Old 05-15-2006, 09:13 PM   #49
A_Stratus's Avatar
Love mine... not just saying that because I'm with TTR/HobbyCraft Canada either. To be honest I did not like it at all indoors. The setup was horrible with it though. I just ran it with a buddy's setup with my own homemade flatchassis conversion from a delta box chassis and it was AMAZING. I still have to make a couple small changes though.
I'm running
7-5-3 for diff fluids
Xray 1.5 pistons drilled to 1/16th with AE oils
35 front (trying 30 in the front next time) and 30 in the rear
Red springs (will try Xray Blues next time out)
2.5 degree rear toe...
shock postioning is outter on both front and back on the arms... most inner position on the front tower on the bottom row, most outer in the rear on the bottom row.
Ride height is level upfront and just below level in the rear
1.5 degree camber all the way around
1 degree toe out
Should be a decent start for you if you get one...
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
Old 05-15-2006, 11:53 PM   #50
INFERN0's Avatar
After running mine in its first race and my first time running the buggy since picking the S3 out I am impressed. The buggy has tons of tuning potential and makes quick turns, now mind you I only had the delta box chassis and I am now about to install the longer flat chassis, so I have not yet begun to tap into the full capabilities of this car. I can say it is a fine car and worth the investment.
Proudly driving for Kyosho America, Team Maclan and RC Pitstop
INFERN0 is offline   Reply With Quote
Old 05-16-2006, 11:38 AM   #51
straydog's Avatar
Sure do like the look of this flat chassis car, gonna be My, New, WHIP,,
I knew my race L.S.T.1 was doomed when I never ran it at Red deer Wint Nat's
Untill it Broke at 1/2 way in the R.C.R.E.Moth Ball it just felt wrong trying to race it,, and,
Figure out what this 1/8 scale ,TTR EB4 S3 "Race Car" is doing!?!
So since I've bien GOOD ,,,,
I'm heading out to the track with a truck load of S3,,, and,
Since the Edmonton Tradesman job market is soo HOT!!
I don't go back to work at my New job with my Old Employer Untilll the 23rd!!!!
OH MAN! Boogety! Boogety! Boogety!
EB4S3/WS7II
Mini Crawler
Old 05-18-2006, 07:20 AM   #52
straydog's Avatar
Wow! Big change in my car with the flat chassis!
Biggest Improvement has got to be how it handles the rhythm section,,,,and
It straighten's out easier on power, oversteer later and slower I can brake later and shorter.
This was a T.T.R. Team car and has many many hrs/gall thru it.
Only one of the susp' blk,pivot ball's comes out rellativley easy
The Rr diff pinion is worn @ 60% [ was allways run greased & wiped]
The front arms have bein done with heli-coils and lite pillow balls
None of the steering linkage pivot balls have a shoulder on them
Lots of S/S screws.
My Box chassis is a new car [@ 2gall,] and in comparison is as smooth as the Box it came in
EB4S3/WS7II
Mini Crawler
Old 05-18-2006, 08:35 AM   #53
I've got a second generation Titan Tech chassis with all parts for sale if someone needs one. I installed and fitted everything, but never ran it so it's scratch free like new. I'll also include a front top plate that I drilled to fit the front torque rod better. PM if you're interested. Thanks!!
Vegaspilot is offline   Reply With Quote
Old 05-19-2006, 01:48 AM   #54
Hi guys i wanted to no if the TTR comes stock with the flat chassis now?
Matthew.H is offline   Reply With Quote
Old 05-22-2006, 05:43 PM   #55
straydog's Avatar
Are the servo arms that come with the S3 kit are they Airtronics??
Seem to fit a Hi-Tech,but not a JR, was told their Airtronics?
I've had issues with my thrl/brk,HS925MG.
Switched to the JR Z590 that comes with the DX3 Radio and nothing fit's....again.
The HS925MG was great, till it Quit responding untill you gave it a little push?
As long as I kept it moveing it would work but ,Stop Sig, Stopped Servo!
What could that be?!?[besides rubish]
Would like to put a couple of servo's in there with no DSM or otherwise BAD History.
EB4S3/WS7II
Mini Crawler
Old 06-01-2006, 04:12 AM   #56
Mr-s413bt's Avatar
Hey guys,.
Just wondering if anyone is using any of the Proline/protoform bodies on their S3's???? i need a shell, but no one has an S3 one
Glenn
Old 06-01-2006, 05:25 AM   #57
Trader Rating: 26 (100%+)
ya they fit perfect, and the roof is hgiher to clear the airfilter, the j-concepts body is really good too, both fit better than the stock body IMO
bobf24 is offline   Reply With Quote
Old 06-01-2006, 12:33 PM   #58
sac
Default stock S3 body
Mr-s413bt
Try www.evolutionhobbies.com for a stock S3 body,they have them in stock.If they are not listed on there website ,just e-mail them or call them.THEY HAVE THE BODIES IN STOCK!!! aswell as S3 parts.
sac
sac is offline   Reply With Quote
Old 06-01-2006, 02:21 PM   #59
Mr-s413bt's Avatar
Hey GUys.
So which protoform shell fits????
Glenn
Old 06-01-2006, 03:59 PM   #60
Scottmisfits's Avatar
The Proline Crowdpleaser 2.0 for the S3 buggy. It's one specially designed for the TTR. The Mugen one will work as well, just needs a little more trimming.
Scottmisfits is offline   Reply With Quote
Thunder Tiger EB4 S2 PRO RTR Buggy Mr. 8T R/C Items: For Sale/Trade 14 11-29-2007 04:21 AM
Thunder Tiger EB4 S2 Pro Buggy RTR simba350 Australia For Sale/Trade 2 01-30-2006 07:25 PM
Thunder Tiger S3 Buggy lazarus R/C Items: Wanted to Buy 0 12-15-2004 05:17 PM
Thunder Tiger S3 1/8th buggy lazarus Oval, Larger Scales and More 1 09-19-2004 11:09 AM
FS: Thunder Tiger EB-4 1/8 buggy windellmc R/C Items: For Sale/Trade 3 07-11-2002 10:51 AM
