Like Tree346Likes
Mugen MBX8
    Hide Wikipost
Old 05-31-2019, 05:05 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX8
Last edit by: E1 Diablo
E2025 - MBX8 Worlds Edition - April, 2019
MUGE0240: Wide Offset Wheel Hubs 1mm 2pcs; The 1mm wide offset wheel hubs will increase stability and cornering.
MUGE2146: Inline Front Uprights; The E2146 inline front uprights have smoother steering compared to the stock E2147 trailing front uprights and work great in high traction conditions. E2146 uprights can be used with both CVA and universal style driveshafts.
MUGE2168: -3mm Front Upright Arm; The -3mm front upright arm improves the initial steering response and make the vehicle more stable through the middle and exit of the corner.. The new upright arms also reduce bump steer and make the vehicle more predictable in bumpy conditions.
MUGE2235: 46T Spur Gear; The 46 tooth HTD spur gear provides a great balance of acceleration and top-end speed.
MUGE2252: 12T Pinion Gear
MUGE2254: 42T Conical Gear; The optional 12T bevel gear when used with the 42T conical gear will change the final drive ratio and increase acceleration.
MUGE2260: Center Joint Cup.
MUGE2261: Center Front Dog Bone (84.5mm)
MUGE2262: Center Rear Dog Bone (115mm); The front and rear-center dogbones for the MBX8 reduce friction from the stock universal driveshafts. Less friction will give the vehicle a more efficient drivetrain, increase acceleration, and provide more traction. The dog bones are lightweight, durable, and will increase traction.
MUGE2428: Rear Wing Stay +15mm; The +15mm wing mount has more adjustment and will help increase mid corner rotation and be more stable in high speed conditions.
E2021 - MBX8 1/8 Nitro Buggy Kit
Chassis:
The MBX8 chassis features a new design that improves traction and stability in bumpy conditions and on the exit of corners. The steering post are also keyed into the MBX8 chassis for easier maintenance.
Differential & drive train:
High Traction Differentials are included in the MBX8. The Mugen Seiki HTD provides increased acceleration, longer runtime, and more consistent handling. The HTD's also increase stability, traction, and improve handling in bumpy conditions. The HTD has a new larger volume diff cup to increase consistency during long main events. This makes it easier to time rhythm sections, better in bumpy and low grip conditions, helps to increase traction, and increases fuel mileage.
The new gearbox makes allows you to remove and service the differentials without detaching the suspension arm mounts. Easy access to the front and rear differential.
New straight cut 13T bevel gear & 44T conical gear. The new straight cut bevel and conical gears increase acceleration, runtime, and efficiency. A free and efficient drive train will also increase speeds while cornering.
Light weight one-piece wing mount:
The new lightweight one-piece wing mount lower the center of gravity. The position of the wing and wing mount is optimized to improve the performance of vehicle. The height of the wing mount is adjustable. This allows you to control the down force on the rear of the vehicle by simply raising or lowering the mount on the shock tower.
Light weight high down-force wing:
The new IFMAR legal wing is lightweight and provides amazing down force and cornering. The underside of the wing uses a new design to reduced weight and creates additional down-force.
Suspension:
New suspension mounts. The FF/FR/RF/RR are new for the MBX8.
The front and rear lower arms use a new impact resistant material for increased durability. The new arms are box-shaped and include arm stiffeners to reduce flex and increase durability. Adjusting the hardness of the lower suspension arms is now possible. This allows you to fine tune the steering and traction from track to track. CFRP plates will be released as an option part.
Center differential mount & plate:
The center differential mounts use a stiffer material and has a new top plate to reduce chassis flex and increases clutch bell, spur gear, and clutch bearing life. The reduced chassis flex also provides more consistent handling in all conditions. The top plate design also makes it easier to adjust the brakes and easier maintenance.
Enclosed Battery box and updated carbon fiber radio plate:
The MBX8 still uses a flat 2S Lipo or Life battery, but the receiver battery is now enclosed in a molded battery box. The battery box allows for quick and easy access to the battery. The molded box also helps protect the battery from hard impacts. The battery box is mounted to an updated carbon fiber radio plate.
Other new parts and upgrades:
Body, Clamping Servo Saver Nut, F/R Shock Towers, Front bumper, Front center and rear center universal joint.
Mugen Seiki MBX8 Manual
Print Wikipost
Old 02-27-2024, 11:26 AM
  #1441
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
offhand for your MBX8R owners, how quick change are the diffs?
For example, got a car here that looked quick change, but the hingepin hangers like A and D blocks are keyed to the chassis, so you need to unscrew a variety of things to at least lift up the diffs to get the block out of the way so the case part can come off, versus just removing the hingepin hanger and then the cover, if at all.
Is the MBX8R like this or doesn't require all that to get to them?
Cain is offline
Old 02-27-2024, 01:31 PM
  #1442
remove the sway bar, 4 fasteners, and it comes apart
Cain likes this.
derricklong38 is offline
Old 02-28-2024, 07:54 AM
  #1443
Tech Legend
Cain's Avatar
Thanks for the info.
With the MBX8R version, assuming parts that are universal between the Nitro and Eco versions, what all do you feel are upgrades required for durability? For example, alloy servo saver piece, etc.
Also, what exactly is the difference between these two parts since the description is the same?
For example Part # E2240 and E2240A.
Trying to confirm some parts in the MBX8R Eco Manual, looks likey they have a mix of regular numbered parts and "A's" with a variety of the regular part # variants showing up on clearance.
Part at least coloring-wise looks slightly different?
Cain is offline
Old 03-19-2024, 06:35 AM
  #1444
pink_sleeve's Avatar
Trader Rating: 221 (100%+)
Any news on a new buggy? Seems they update every 2 years or so.
pink_sleeve is offline
Old 03-19-2024, 01:09 PM
  #1445
Tech Legend
Cain's Avatar
Wondering the same thing since the vehicles seemed to have gone out of stock ...
Cain is offline
Old 03-21-2024, 01:06 AM
  #1446
morgoth's Avatar
It's always around november-january that the new buggy is released. Since we're already the end of March, I don't think we'll see something new anytime soon.
morgoth is offline
Old 03-31-2024, 12:23 PM
  #1447
They seem to be working more on the 1/10th buggy at this time. As the last person said it will probably be at the end of the year or early 2025.
homerdaman is offline
Old 04-03-2024, 06:49 AM
  #1448
HOTROD716's Avatar
How compatible are the setups from the ECO to the Nitro? I know in some other chassis the electric and nitro are close to the same setup.
HOTROD716 is offline
