Go Back   R/C Tech Forums > North American Regional Forums > Nebraska Racing
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-25-2007, 09:34 PM   #1
celeritas's Avatar
Thumbs up Tamiya Mini Zone (M03 chassis)
Well I thought it might be time for this thread.
The class is growing very quickly and this may be a good place to share set-ups and answer all of the questions noobs like me have. Let's keep it specific to what's working at the local tracks.
What hop-up parts are working?
Springs?
Shock oil?
Tire inserts?
Differential?
Tires?
What other mods have you made to the car?
Thanks in advance.
celeritas is offline   Reply With Quote
Old 01-26-2007, 04:12 AM   #2
Matt Howard's Avatar
Got this setup from Todd while I was builiding my car sunday morning.
Front- 80wt oil with 3 hole pistons, short blue springs, shocks built to 56mm
Rear- 40wt oil with 3 hole pistons, short yellow springs, shocks built to 56mm
-Ball diff
-4 bearings added to the gearbox
-water dipped my motor for 30 minutes to seat the brushes
-only put traction compound on half the inside tire in front, full rear
-pull the trigger and have some fun
Official member of The Guild of Calamitous Intent
Matt Howard is offline   Reply With Quote
Old 01-26-2007, 07:01 AM   #3
Here's a nice article on race prepping your mini, if you want to go full out with the hopups
http://www.tamiyausa.com/articles/fe...?article-id=12
Old 01-26-2007, 07:59 AM   #4
padailey's Avatar
Well it should be 6 bearings...
I haven't done anything but bearings, springs and saucing the tires. I did do some work on the friction dampers to lower the car but that's it. Curtiss Driver only did bearings and was right up near the front. By the end of Wednesday night I was running right in the mix. Just my driving holding me back, the car was great. I'm gonna try and not make any more changes for a bit and see how it works out. If you guys haven't seen this site check it out.... www.rc-mini.net.
#42 Pegasus Mustang
www.hobbyplexraceway.com
padailey is offline   Reply With Quote
Old 01-26-2007, 01:08 PM   #5
golgi's Avatar
Cool, I didn't know you guys going were racing those? I was hoping that sooner or later these types of races would happen in the area.
Are these things front wheel drive or rear? Have you already started racing them or are just thinking about starting? When will the races be? I may have to get one as I'm a Tamiyaphile.
golgi is offline   Reply With Quote
Old 01-26-2007, 02:01 PM   #6
padailey's Avatar
Racing has started on Sunday afternoons and Wednesday evenings. So far everyone is racing M03's which are FWD. Not sure if the M04's are allowed. Tim would have to answer that. Last couple races I've raced at there have been 9-10 entries. The way they have been selling though we could have around 15 this weekend and I wouldn't be surprised if it hits 20 before too long. It's a Hoot!!
#42 Pegasus Mustang
Old 01-26-2007, 03:25 PM   #7
celeritas's Avatar
Yeah!!!
Good to see your post!
The class started a few weeks ago.
Everyone is running the M-03m chassis (FWD). The Suzuki Swift 1600 kit.
Venom 3000 stick packs are the spec battery.
Old 01-26-2007, 04:51 PM   #8
celeritas's Avatar
Awesome article, thanks.
This thread is already paying off!!
Next question, could you please explain the theory, and practice of breaking the motor in with water?
Old 01-26-2007, 11:54 PM   #9
warpig's Avatar
It's self cleaning load bearing break-ins. Use a glass of water (not drinking water or anything with salt due to the ions) and set the motor in it and run at low voltage for a few minutes.
Note, Kevin did it with a pinion and said he made a vortex. So, no pinion! haha
warpig is offline   Reply With Quote
Old 01-27-2007, 05:53 PM   #10
celeritas's Avatar
What voltage?
What amps?
How long?
Old 01-27-2007, 06:28 PM   #11
Originally Posted by celeritas
What voltage?
What amps?
How long?
I dipped mine at 3 volts for 30 minutes
Old 01-27-2007, 06:40 PM   #12
celeritas's Avatar
Thanks, Matt
What pinion gear are you guys running?
Old 01-27-2007, 07:09 PM   #13
tbeardmore's Avatar
Thanks, Matt
20T... that's what comes with the kit
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 01-27-2007, 10:38 PM   #14
celeritas's Avatar
Is that the only pinion allowed?
Old 01-27-2007, 10:57 PM   #15
padailey's Avatar
Per TCS rules 20 is the max pinion size. You could run an 18 or 19 also but I think that is all that will fit without modification (which would be a no no).
#42 Pegasus Mustang
Forum Jump
Mini Zone. Trinity clash or something? air8 Electric Off-Road 0 06-13-2007 04:25 PM
Tamiya 1/10 RC Mini-Cooper - M01 M-Chassis bizkit1 R/C Items: For Sale/Trade 0 10-18-2006 07:55 PM
Hello - Tamiya M Chassis M03 Mini From Chile cuesco Electric On-Road 12 10-12-2006 11:27 AM
What is the best tamiya mini chassis M-03, M-03L or M-03M Hicksey Electric On-Road 1 08-17-2006 02:35 AM
which is better tamiya TZ or z-zone eagle (both 23T) nikkiesteban Electric On-Road 10 06-04-2006 09:36 PM
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
