NESCAR R\C Raceway Grand Island 2014 Oval\Offroad
#61
2wd SC Class
I may try to run the 2wd SC class. It has all of the requirements to run minus better tires. The titan brushed motor should hold up fine but I could always swap in the VXL system from the 4x4. Is the meeting at the end of Feb open to anyone or a select few?
#62
Everyone is welcome and encouraged to attend the meeting. It is a great way to meet some of the racers and ask questions. Your 2wd with the titan would work just fine for the nespek class. If you toss the vxl in your 2wd it would work for the mod SC class. Or we will be looking at possibly running the vxl system on 50% throttle in the nespek class. This is something that still needs to be tested before its approved.
#63
Meeting
Sounds good. The vxl esc i was going to use in the 2wd went south. The button sticks down so it cycles thru modes non stop. My daughter and i will try to make it to the meeting, weather permitting.
#64
Tires and rims ordered. What specs of lipo should I get? I know I need 2s but what c rating is best? Sorry for the newbish questions but I am still rcing old school style. I didn't need to upgrade to have fun.
#66
Ecx circuit
I posted a pic of my daughters ecx. All is upgraded except the steering which still has a ton of slack in it. Does anyone (or a friend of a friend of anyone) know what can be done to fix this? I am getting her a trx 2056 servo for her 6th birthday and need suggestions on linkages.
#67
I can't help much on the slop in the steering since I haven't run a ECX or even handled one. About the only thing I can say is to check your servo saver to make sure its tight enough. Also all off road cars are going to have some kind of play in the steering but since this is the only car that you mention and you said you have others I am guessing this is worse than normal. Just take your time and look carefully at all the moving parts. Turn the front wheels by hand back and forth slowly to see if you can see anything moving more than it should.
#68
Ecx circuit
The slop runs thru the whole front end from the hub to the bellcrank and up to the servo. I am going to start with the servo and steering links and see where that gets me. It looks like it could be an over generous servo saver now that u mention it. Thanks again for the advice.
#70
My daughter and I will be coming to the meeting if everything goes according to plan. Who should I ask for when we arrive?
#71
We will be in the party room at the south locust pizza hut. Just come on in and have a seat. If you would like to talk to someone right away then Al is the club president and he will be there. Otherwise pretty much all of the racers are nice people and you can talk to any of them also.
#73
Well that was fast Andy. Aparently all you needed was for a 4x4 SC class to start up to get that thing to sale.
What classes are every one planning on running? What are you going to run on points days and what are you going to run on non points or trophy days. My current plan as long as there is enough is to run 2wd stock buggy and 1/8 buggy for points, than alternate between 2wd and 4wd SC on non points and trophy days.
#74
2014 Offroad class rules
2014 Off Road Rules
NESPECK Beginner Class
prefer 17.5 motor or regulated motor upon disgretion of Club Officer
2s lipo battery
Any car or truck
2wd Buggy Stock
Any 17.5 motor
Any Speedo/Programable Blinky mode
2s lipo battery/any tire
ProLite SCT
3800kv motor or 10.5 motor
Speed control Sportsman or Prog Blinkey
No 4pole 1/8 speedos and motors
2s battery
No 1/8 scale tires
4x4 SCT Open
Any motor/any 2s lipo
open speedo
no 1/8 scale tires
1/8 scale
Speedo/Motor
Any Battery/tire
have fun
2s lipo battery
Any car or truck
2wd Buggy Stock
Any 17.5 motor
ProLite SCT
2s battery
No 1/8 scale tires
4x4 SCT Open
open speedo
no 1/8 scale tires
1/8 scale
Speedo/Motor
Any Battery/tire
have fun
#75
2014 Oval Class Rules
Nescar 2014 Oval Rules
Street Stock Speed Passion 21.5
2wd Buggy chassis no oval modifications(AE,Losi,Kyosho,etc,,)
McCallister Street Stock body
Non Progarmable Speed Control/Speed Passion 21.5 Ulta Sportsman motor/Comp motor with Locking plate
Battery Venom 3200 20c Part#1553,Venom 3300 25c
Tires AKA Impact 13107v/13107s or Proline Hole Shots Any Fronts
B/Modifieds 17.5
IMCA Apperaing Modified Body (No EDMS)
Speed Control Sportsman No Programable Any 17.5 No D3.5's
Buggy Tires Open
Battery Rule Open
Short Coarse LateModel/SC Modified
2wd short coarse truck chassis
late model short coarse body/SC Modified Body
Any 3500 kv motor or 10.5 motor and blinky/spec speed control
Any short course tire (no 1/8 scale tires)
any 2s lipo battery
13.5 Late Model
Any 2wd chassis
late model body (must fit within DODC Rules)
Any ROAR 13.5 motor/ blinky or sportsman speed control
Any 2c battery
Any 2wd 1/10 buggy tires
Sprint Car
Any 2wd chassis
Any 13.5 motor/ blinky or sportsman speed control
Any 2s lipo battery
7x7 wing
Outlaw Street Stock
buggy chassis no oval mods
13.5 motor and Any speedo Blinkey Mode if programable
Any 2s Battery/Any tire/Any Motor
2 inch spoiler and Mc Callister approved Street Stock Body
rules are subject to change for the betterment of racing by President/VP
B/Modifieds 17.5
Buggy Tires Open
Battery Rule Open
any 2s lipo battery
13.5 Late Model
Any 2wd chassis
Any 2c battery
Sprint Car
Any 2wd chassis
Any 2s lipo battery
7x7 wing
Outlaw Street Stock
