New For 2010
New For 2010
Novice: Motor Limit: Open
New Class: 17.5 Sportsman (roar rules apply)
New for VTA: (USVTA rules apply) with the exceptions of Novak,LRP,KO,and TEKIN ESC are allowed
All Esc must be set to their lowest setting
NO Advanced Timing or Boost
LRP must use profile 4 or lower
TEKINS must use version 200 or eariler with no turbo and no more than 10 degrees timing(this is a starting point)
KO same as TEKIN
NOVAK any profile
NO Black Diamonds or Mambas allowed
Ratio: 21.5 motors must run 5.2-6.0
25.5 motors must run 4.2-6.0
Tire Rule:Must have visiable tread at start of Qualifier and Main
Mini: We will run the red dot motors (15K)
Trailer: Rebuild was approved. New tires,New jack,remodel(Sean),paint
KO same as TEKIN
NOVAK any profile
John jolly will be maintaining these and checking rpm range.......
this will even out the class.......so for $20.00 you get a faster motor(than stock) for a year!
this is for regular club and cup races not.....TCS,BTH or FallOut!
Races
Hope this helps......
Later!!
The Mini motors are preped and speced Tamiya 540J motors. They are all matched at 15K RPM @ 5 volts.
The red dot motors are for qualifying and mains only. You must provide your own for practice.
