Rd 3 RC Pro Slash NCCS June 20th Bullet Town!!
Signups are open for round 3 of the RC Pro Slash NCCS at Bullet Town on June 20th. We have had over 20 slashes in both the first two rounds, would love to see that again in round three, really heaps on the bonus points for the series. We will also be club racing all other classes. Come join us for a fun filled day of racing at THE BULLET!!
Get signed up at www.rcsignup.com
We will also be giving away some Pro-Line Gift Certificates away on the 20th, so make sure to come out and have a chance at taking one home!!
i think this is all but i dont know, i copied and pasted this from the summer series thread so i dont know if the is nccs or what, but i think these are the basic rules.
IF THE RULES DON'T STATE YOU CAN DO SOMETHING THEN IT'S NOT LEGAL
Slash Spec
CHASSIS
1. Modifications of any type to the chassis plate, lower braces, receiver box, battery brace and related parts are not allowed.
2. The battery must be placed in the battery tray. The foam battery spacer may be placed behind or in front of the battery when using a 6-cell battery pack, or removed when using a 7-cell battery pack. Cutting or otherwise modifying the spacer is not allowed.
3. The side nerf bars, front and rear bumpers, skidplates and body mounts may not be removed or modified.(THERE MAY BE AN EXTRA SCREW ADDED TO THE REAR BUMPER TO BETTER SECURE IT.)
SUSPENSION
4. Modifications of any type to the suspension arms, shocks, shock towers, hub carriers and related parts are not allowed.
5. The stock shock pistons must be used in their factory positions and may not be modified. The Traxxas Aluminum Shock Caps ( 2667 aluminum shock caps) are legal.
6. When refilled for maintenance, the shocks may be filled with any weight fluid. The shocks must be properly filled with oil.
7. The stock shock springs must be used in their factory positions. Springs may not be shortened or otherwise modified.
8. Spring preload may be adjusted using only the supplied spacers. Additional spacers may not be used.
9. Front toe-in and front and rear camber may be adjusted within the travel range of the factory turnbuckles and rod ends.
DRIVETRAIN
10. Modifications to the gearbox, transmission gears, slipper clutch, driveshafts and bearings are not allowed.
11. Each track must set a pinion rule based on what is best for the individual track. All racers must run the specified gear. Gears must be made available for inspection if requested by other racers or race officials. Spur and pinion gears are allowed to be after market replacements for the Traxxas.
12. The differential may not be locked or modified in any way.
BODY, WHEELS AND TIRES
13. The factory tires and wheels must be used and may not be modified in any way.
14. Softening compounds or other traction aids may not be used.
15. A Traxxas Slash body or aftermarket body specifically sold for the Slash must be used and may not be modified in any way other than the addition of decals or paint. The body must be mounted using the factory body posts. The body must be trimmed using the factory trim lines, and may not be modified in any way other than the addition of decals or paint.
ELECTRONICS
16. The original Traxxas XL-5 speed control and Titan12T motor must be used. In the event of motor or ecs replacement the Traxxas XL-5 and Titan 12T must be used. No other esc or motors will be allowed.
17. Aftermarket transmitters, receivers, and servos may be used.
18. Motor and Esc connectors may be changed or eliminated. (Note this may void any warranties from Traxxas)
19. The motor's label must be intact. Motor modifications of any type are not allowed.
20. Piezoelectric gyroscopes or other stability-enhancing electronic devices are not allowed.
TRANSPONDER
21. The transponder must be mounted beneath the Slash body, either on the body itself or on the chassis plate.
BATTERIES
22.NIMH, NICD 6 or 7 cell packs are allowed.
23.Lipo 2S are allowed and must add weight in the battery box only to equal the 7 cell weight.
REPLACEMENT PARTS
24. Only Traxxas original replacement parts may be used or aftermarket parts specifically noted in these rules.
25. The following Traxxas upgrade parts are legal for Slash racing: 2667 aluminum shock caps.
26. The following aftermarket upgrade parts are legal. RPM gear cover.
The idea for this class is to keep it spec and affordable. In the process of the year we may find other areas where an upgrade part or aftermarket part may be needed to make the trucks more reliable. Because of this additions may be added at any time. Upgrade suggestions must come from the participating tracks and be based on an unusual amount of breakage.
Slash Spec
CHASSIS
SUSPENSION
DRIVETRAIN
ELECTRONICS
TRANSPONDER
BATTERIES
REPLACEMENT PARTS
