Traxxas X-Maxx
#843
Werner: you're talking about that reverse take-off 360 back flip deal the slash pulled?
I consider you to be one of the best 'stunt' jumpers, do you think this jump was just lucky, or is it something that is repeatable?
#844
traxxas's driver manages this 180° starting in reverse with the slash ( 2 times ) and the xmaxx also. it wasn't luck : they start in reverse, slightly steers the wheel, hit the brakes and this creates a rotation : it helps to have a wide ramp. so they did some work and will surely try those jumps live
I didn't work hard on jumps in reverse, but there is some funny things to do !
I wrote some comments on this traxxas vid and they nicely replied : I told them to name their jump !
Good to see a manufacturer pushing the freestyle side of RC's
#846
Run #84. Mostly just getting used to camera mount. Trying to keep things in frame
https://youtu.be/48PMhfYzS3I
#848
Here is video of the Hinge Pin mod for the Traxxas XMAXX RPM Racing arms.
https://youtu.be/UP8D4mqHXnI
#851
Here is the Center Diff lube or whatever they call it. My Brother in-law took his new 8s rig apart to change to a known fluid thickness. Said it is not dirty or sticky on hands. Not grease. Maybe silicone. Anyone know what this stuff is?
What are you guys using for center diff lube?
#852
After a break back running the 8s. New camera mount works much better here.
Run #8. Big hill.
https://youtu.be/Mf__AbVJnK4
#8b. Slow motion
https://youtu.be/hYEuVLmoKOY
Run #8. Big hill.
#8b. Slow motion
#853
Proline released the X-Maxx specific wheels/tires today:
https://www.prolineracing.com/tires/...tires-mounted/
Highlights:
Tire Features:
Incredible Traction on Any Surface
All New Ultra-Durable and Anti-Ballooning Tire Compound
Aggressive Motocross-Inspired Appearance
Reinforced Tire Bead
Ground Breaking Proprietary Pro-Loc Technology
Tire also available Un-Mounted
Foam Inserts Included
Made in the USA, since 1982 – Read about Pro-Line Racing’s History
Wheel Features:
Ground Breaking Pro-Loc Mounting Technology
Change Tires or Foams and Re-use the Wheels
Tough, Blacked-out Impulse Wheel styling
Extra Thick, Extremely Durable to Take Serious X-MAXX® Abuse
Stone Gray Bead-Loc Rings Stand Out from the Crowd
Wheels also available Un-Mounted
Highlights:
Tire Features:
Wheel Features:
#854
Highlights:
Tire Features:
Wheel Features:
Highlights:
Tire Features:
Wheel Features:
