Emaxx Shock Replacement Options
#16
I was really hoping that those Ofna shocks had threaded bodies. I might look into Losi shocks or go with Traxxas big bores and some type of other stronger springs. I wish this was easier or there was a proven shock setup.
#17
Firstly, every truck should bottom out lightly for it to operate normally. If it doesn't all of the weight will load on the shocks, and you will be replacing shafts & rod ends "every" run. Secondly, you are not going to be given an off the shelf option, as your truck is built differently to almost all others, with various aftermarket parts you chose to your taste. So google builds that are similar to where you want yours to end up, and use that information to make your decision. Thirdly, there are plenty of trucks heavier than yours, you are still running a stock chassis. As mudbug said Hyper fronts are a good length, and would take the weight of your truck easily. If you want threaded bodies, then google it and find some. If you want to run only 4 shocks, use stiffer OFNA springs, if you want to run 8, then run medium to soft to suit your preferred driving style...
#18
Just looked at the pics of your truck. The springs you are running appear to be the 3x7x3 not the 12Lb. With the truck you show, those shocks you have will work fine. I run them on my basher in the LCG chassis with no problem. The basher truck of mine weighs 18Lbs with the aluminum rims and Mudslingers think it lands lightly?, no, but slightly, yes. You should just accept the fact that the truck needs to land on the chassis. That's why folks use cheap skid covers, they are expendable. If you want, there are TiNi shafts available for those shocks, but you shouldn't need them. You shouldn't need preload spacers on any shock you choose since I see FLM towers. 80w oil is much to thick practically "0" dampening effect, at most use 50W. Plastic rod ends are not reusable once they pull out or you take them off just throw them away. Can't glue them or JB Weld them they are garbage. Get some alloy rod ends, problem solved.
Don't mean to sound bossy here, just telling it like it is
#19
I understand how to use Google guys, but the options for good quality Shock options aren't there like they use to be. I wanted either Proline or UE shocks. Not made anymore. I want a shock with 3.5 - 4mm Shock shafts. What I want is not there unless I go with another brand of shocks from another manufacturer. Even then, that doesn't tell me that they will fit or there are Shock mounts to adapt them to the towers with the correct amount of spacing.
Integy and the like is junk, so where does that leave me? That said, a simple Google search does not give me the answers.
Also, where are you guys finding the metal Shock ends?
#20
#21
Best I can tell you at this point is.... Find some shocks, then give us as much info about them as you can before you buy them. Maybe then we can be of some help. Or do as Sam suggested take one of your old shocks to your LHS and match them up.
For shock ends, wouldn't worry about that till you figure out what shocks to run .
I have found some shocks on eBay for the extended chassis of mine. They are pretty much what you are looking for. Will not give them an endorsement yet. As this is the first time I have run them. Will get into more detail with links when I get back to my computer later tonite.
#22
What I do know about these shocks
http://www.ebay.com/itm/Aluminum-Big...item1a03afbec0
1. They came with some really thin o rings for caps seals that don't work. Fixed them with these http://www.nitrohouse.com/14mm-Shock...rs_p_6150.html These seals are a little to large for the cap. But can be easily maneuvered in to fit and seal tight.
2.They are 14mm aluminum with threaded shock bodies
3. Any spring for a Maxx will fit
4. 4mm shafts
5. They look good IMO
6. The springs retainers are a little on the large side. My steering turnbuckles which are not stock Traxxas parts rub very slightly on them. I believe a stock turnbuckle would have no clearance issue. The turnbuckles I run are fatter than stock.
7. 2 hole pistons
8. Have no idea of who manufactured them or if replacement parts are available.
9. I assume you have FLM shock standoffs..... The shock mount on the cap is too fat and will have to be ground slightly thinner to work properly with the FLM stand offs
Other than that I can't tell you anything. I have run one full pack on this truck with those shocks. So if you decide to buy these do so without my recommendation.
4. 4mm shafts
7. 2 hole pistons
#23
4. 4mm shafts
7. 2 hole pistons
4. 4mm shafts
7. 2 hole pistons
I even sent the seller two questions regarding the shocks and did not receive a response.
At this point, I am looking at either going with Traxxas Big Bores, Ofna 7 shocks or some Losi shocks. The Losi shocks with be the most expensive, but I'm certain they would be the best. Now this leaves me with finding all of what I will need for them to make them work and then evaluate the cost and the worth of going with them.
My build will have 8 shocks. 4 shocks were considered, but I am just not certain if they would be enough.
Sigh, I wish this was easier.
#24
I used 8 Ofna LX1, LX1e buggy front shocks on my old Emaxx build with the stock yellow springs found on the nitro buggy. They worked great out of the box and a fluid change made them even better. They're threaded body, fit through RPM arms and mount like Traxxas shocks. The buggy is discontinued though so finding them (especially new ones) might be an issue. UE Supershocks are Ofna LX rear shocks modified with shorter shafts to prevent bottoming out the shock and blowing it out.
#25
4. 4mm shafts
7. 2 hole pistons
4. 4mm shafts
7. 2 hole pistons
#26
You might want to try the Ofna Hyper 7 front shocks they work great. Much beefier than Traxxas shocks, I have a hard time justifying spending money on anything Traxxas anymore. When there are much better parts available that are less expensive.
Time will tell on those aluminum shocks you had mentioned. Got a decent price on them and so far they are working great. If they end up being junk for a runner, then they will work for someones shelf queen with a little cleaning and polishing.
#27
#28
Traxxas big bores are a great cheap option. They fit without issues, rebuild kits are cheap and in stock everywhere, they do not bend shafts and they do not leak. And there are tons of spring options available cheap too. VG racing makes the 12ppi springs and they will hold up your truck no problem.
Those silver ones mudbug posted are crap. They are made by Kinghobby, who illegally makes low quality clones of other peoples work. You should avoid that seller (actually you should report him to ebay any time you see his items), and avoid anything made by him.
#29
My deciding factor is being able to get parts to rebuild when needed.
#30
Pretty sure the Ofna's have a 4mm shaft....... Would have to go out the work shop and measure them to be sure.... I do know they aren't 3mm
