Dual Hv Maxx T maxx Killer!
#16
Originally Posted by Platinum_Racing
7075 doesn't come cheap. That price is pretty high...if we made those we would probably only charge about $100-$125 or so. They are just praying on the fact that they are the only ones with such a complex tranny. Getting the stuff perfect on Autodesk Inventor is probably the most time consuming part of the whole operation. There are single speed steel conversions, but that keeps the 2 speed with stock ratios so it is a bit more complex.
Inventor's a pain in the ass. I'd actually guess the expensive part is hobbing the gears. First, you have to cut a blank that is within one-thousandth, then you hob the teeth. It really is a complex setup.
Off topic-Plat, do you need a machinist and drafter, fresh from school, with a 131 IQ, outstanding spatial ability, and a complete understanding of everything mechanical?? I need a job.
What machinery do you run? I'm well versed in G-code, AutoCAD 2000lt, 2005 and 2006. I can send pics of things I've made, both R/C and non.
#17
I use Autodesk Inventor mainly for part design and prototyping (Not to mention fooling around...SHHHH! ), but I am also familiar with AutoCAD 2000, AutoDesk Architectural (I don't know why...Taylor's the homebuilder, I can't even put up a wall! I'll staple myself to ... myself!), and AutoDesk Mechanical. Mainly we use Inventor, but we have the other programs too. I also used to use G-MAX and 3D Studio MAX 2 and 3D Studio MAX 5 for designing 3RD party car models for computer games. Look up my first website endevor called JAGSGAMES. I used to modify games like REVOLT, Gearhead Garage, NFS:HS and NFS3:HP. I also dabbled in Microsoft Flight Simulator but it was too damn hard to get right, so I stuck with modeling cars.
The computer I use is an AMD Athlon64 2800+ with 1GB DDR 3200 memory, running the K8 800T chipset. The ATI Radeon 9600XT 256MB videocard has plenty of grunt to tackle any 3D renderings, as well as goof off work like Doom 3 and HLČ. Call Of Duty is also my specialty !
#18
Can we wake this thread back up please?
I still havent' came up with a good answer to my weak transmission problems. This truck sure looks pretty on the shelf.
#20
WARNING: MY OPINIONS
Get a Robinson slipper and steel spur.
Adjust new slipper properly.
Get a Top Flite prop balancer.
Balance tires.
Remove diffs.
Throw away diffs, saving ring gears.
Weld ring gears to Traxxas spools.
Install.
Get a helmet.
Wear helmet during testing.
You'll thank me.
#22
I decided to tear it down and get to the bottom of what was going on.
Check this out! The center of the plastic spur got soooooo hot that it melted!
I have a Robinson slipper with a steel spur on the way.
This does have me worried about the integrity of my transmission though. Would the stock setup live if I just add some grease?
#24
http://www2.towerhobbies.com/cgi-bin...?&I=LXXF50&P=Z http://www2.towerhobbies.com/cgi-bin...?&I=LXXF53&P=Z http://www2.towerhobbies.com/cgi-bin...?&I=LXXF46&P=Z here is some lighter and tougher tranny stuff, the lighter shafts would be for less rotating mass helping your gears a little bit, less weight for them to turn.
#25
and here is unlimited engineering steel idler kit http://www.unlimitedengineering.com/...ore/13407.html which may help, so thats the input gears and shafts and idler gears and shaft so your tranny should be better afte this, i dont know what other gears ar ein there though.
#26
and also lock your tranny in second gear, shifting under power will nuke the tranny. im unsure how to do that but i figured id re-read the article about this twin hacker e-maxx this magazine built, came to 3 grand for this truck and they could only use 1 motor, 2 was just too much the front tires wouldnt stay on the ground. these motors are supposed to be equal to .40 nitro engines and this truck hit 43 mph. they also used robinson racing steel diff gears and mip cvd axels.....and alum hex wheel hubs in the drivetrain. hope i helped out.
#27
Kicks the Post back to the top of the forum LOL
#28
finally got myself a pair of ultramaxx tranny gears...cost me a bundle...this tread inspired me..once my e maxx is done i will post it up...
#29
hehe...heres my dual HV-MAXX EMAXX hehe...after 10 runs still looking good...those ULTRAMAXX gears was well worth it...take a look at the set up
#30
no offence or nething but that truck looks pretty damm stupid if u ask me no offence but it does and the main reason ur screwing up ur tranny is because uve got aBIG load of alloy and all the torque isnt pushing the truck untill it starts moving thats y ur slipper has melted
ITS CALLED USING UR BRAIN MY FRIEND !!!!!!!! o and ps go for a savage u dont need to upgrade $hit
