Savage flux xs
#16
Nothing will make the transmission quieter as long as you're running a motor with iron-core armature coils. The iron cores interact with the magnetic rotor at all times, even when the motor isn't being powered, and that's where the ratcheting sound originates. Get a coreless motor; I use a Tacon 3970KV motor, and it's nice and quiet, but even being "just" a 2-pole motor it still does backflips no problem. (for the record, I'm using a Trackstar 120-amp short course ESC -- it runs smoother than the stock ESC and costs half as much.)
I have an Integy wheelie bar that bolts to the underside of the rear skidplate, and has a single rubber wheel. (most wheelie bars for anything smaller than 1/10-scale use plastic wheels, which do nothing to help keep the vehicle moving in a straight line.) The wheelie bar is designed for "riding wheelies", as you describe it, but the mounting plate is just a piece of sheet-steel, so you could bend it down until the wheelie-wheel is nearly touching the ground. Keep in mind this will reduce your off-road clearance, though, but if you don't drive off-road then maybe you don't care.
Full details on my build: http://www.rctech.net/forum/electric...e-xs-flux.html
As for Rc Hobbiest asking questions, why do you think he needs to start a new thread? He's basically asking the same questions as the OP. There's no harm in expanding this thread some.
