MRAP BUFFALO AKA BONE CRUSHER 1/10 mostly scratch
MRAP BUFFALO AKA BONE CRUSHER 1/10 scratch FINISHED
HELLO EVERYBODY
I figure I share one of my scratch builds
finally able to get started on this build, ive been wanting to do this for along time. I believe ive done enough research and download enough pictures to get start
like all my builds it wil be r/c with a working arm . ive scale this out to be a 1/10 which is really big, somt times I think I take in to much paint fumes . lol
ive measured this out to be around 790mm, tires are 126mm using 2.2 rims
theres going to be a lot of 3 steps forward and many steps back . im going in 1/2 blind on this and don't know what walls I will be hitting. im assuming around 400-800 hours ,
so this will be great winter coming build . well enjoy the movie and lets get started
ive cut the frame rail, I some what know where the axles go, I need to make the lower hull 1st. ive started by intergrading the rails in the hull, starting from the front
so far everything is located at the right height and right place , I do have to make some new frame rails as these are alittle short . but in the mean time I will work with these to see rear everything else goes . running from the front leaf to th axle is a stabilizer , I have to make these and the mounts
transmission is in place and front drive is installed , working my way back , the transmission is a rc4wd r2 single speed with a 55 turn motor, I cut new frame rails at the correct length this time at 29.5 inches
next I made a transmission cover , heres the basic piece. next I have to sand and detail alittle , and drill some mounting holes
I usde a high torque servo and mounting it to the frame ,then I made a steering box
it will be a beauty when finished, thanks man !
wahoo! tires and rims are in
ive started on the walker beam suspension, there is a lot of parts in volved , but heres the basics
time to work on the rear suspension, 1st I drilled and tapped some holes in the yota axles, ive added a ball end
next ive add the ball ends to the belly and added 2x links, this will keep the axle leveled
next Ive added a cross stabilizer
drive shafts installed and a glimpse at it with tires on it
it must of been really cool to work on them,
very good job !
I never saw such fenders (on the real one) !
ive started on the upper hull, I wanted to do in a one piece, but again some where down the line I would need to take apart, but the cap/roof will be one piece . in side the hull I made 1/8 metal ribs, will cover with .040 plastic for interior
made the exhaust, was hoping to use the Tamiya big rig, but wrong, this is 2x the size, the main exhaust is 1 inch pipe . crazy big man .
next is the windows
started on the rear door
made the inner door
made the outer door
working hinges and door latch is made
next is the windows
made the inner door
made the outer door
you sir, are an artist !
