MRAP BUFFALO AKA BONE CRUSHER 1/10 mostly scratch
#31
I put the inner panels on the hatches and made some handles
next I put some angles under the windows
I made some rear antenna mount
made some rear light mounts and use the knight hauler light buckets, perfect size
I started on the rear ladder, here i used hollow plastic tubing, solid metal rod for shaping and a threaded rod for mounting
upper and lower ladder is made, hinged and mounted, here it is pictured up
pictured down , now i need to sand and add diamond plate for steps
heres the 1:1
heres the 1:1
#32
thanks guys
made the mirror mounts, added the diamond plate on steps and add couple things here and there
I made the next part for the mirrors, its the outer casing, next is the inner mirror
inner mirror holder is done, I will attach mirror when I dine painting it
the truck has a crank, pully set up for the tire lift , its a 2 part system
today I made the fender light buckets and installed the lights, they work great
#33
today I started on the roof mounted search lights, basically all scratch . im using .040, .060 styrene and clear .010 styrene , the light bucket is from the rear bumper of a king hauler . the driver will be able to rotate the search light from the inside. I will add lights later
cant wait for paint and the round styrene to come in so I can finish the roof, should be here Thursday
so in the mean time, I will get started on the bumper,i was able to mod the king hauler front bumper mount for this part
next I using a solid 1/4 x 3/4 inch alum bar for the main support
next I made the hydraulic arm support
here I start wrapping the alum with styrene
1st I notice the bumper was sitting 8mm to low , so I had fix that will quick. ive added some side orange refecters , a ladder and started on some kind of unit that mounted on the top bumper, im thinking its some kind of hydraulic block
#34
today I started on box that's mount on top / center bumper, not sure what the function is, so I was thing maybe hydraulics or electrical . any way here it is. also made the right head light with working door
both light buckets almost done
time to catch up on some painting
started on the interior
#35
a lot of painting to do and a lot of reassembling
hopefully everybody had a safe and wonderful holiday
but break is over, time to get back on this beast
motor is mounted, wires add, the base is in closed and 1st arm is prefitted, inside base is metal and out side casing is plastic. motor is 600:1, plenty torque
added more detailed parts , cany wait to put some paint to these parts
started working on the cylinder and the arm
working on the second arm
#36
#37
#38
#39
#40
That's crazy dude! Thanks for sharing for real. Real pleasure to follow the thread.
#41
