T's Losi 8ight-T 2.X adventures (Leopard 4082, Alien 4092, TP4070 40x102mm @6S)
#16
It's currently in street mode because I'm too lazy to clean it after running muddy fields, but in Summer it will return back to it's true lawn shredding purpose .
#18
Yeah, going WOT is not very easy off-road with >70 mph gearing... I want to see what it can do on street now a bit with some tall gearing, but for Summer I think it'll get its Badland shoes back again and I'll gear back down to 70-ish mph.
#19
Time has gotten a bit scarcer lately, so making only little steps at a time, but at least it's driveable again .
Shimming up new Losi motor mount with cosmic grade aluminIum to reduce play between parts.
Shaping TBR bumper into front wing mount.
Motor mounted up with 27/35 gearing (146 kph, 91 mph no-load).
Next to project X.
Just testing, would fit.
Next to project X.
#20
would bang !
#21
Bang good!
Decisions, decisions...
Arrma Typhon buggy wings; don't worry..., both still need to be cut into desired shape.
#23
Cool thing of the PS-55 is that it's really easy to touch-up the paint if you flip or scratch it. E.g., this pic:
is taken after this happened:
Apart from a heat blister in the lexan produced by sliding belly-up over the street at high speed, the scratches were easy to get rid of with some sand-paper and a few new layers of the PS-55.
#26
Thanks, been a fun build!
#27
Thanks! I have no special painting skills whatsoever (I actually suck at it pretty badly) . Paint is simply Tamiya PS-5 Black on the inside and Tamiya PS-55 flat clear on the outside (~3 layers I think).
#28
^ Thanks!
Nice weather today, so time to finally test the new set-up. Gearing was 27/35, for a no-load wheel-speed of 146 kph (91 mph). Was a quicky, so no videos yet unfortunately... only had time for one pack. I didn't drive it in a long time and space was a bit limited, so I only dared to bring it up to a GPS recorded 109 kph (68 mph), which it would do within 3 seconds and within a distance of 50 m from standstill. Was fun to be out with it again . To record a good top-speed with the 1 Hz GPS logger I need some more space and confidence. Might try to find a cheap Eagle-tree GPS sensor, as those log with 10 Hz.
I changed too much at the same time (diff fluids, shock oil, spring rate and tires), to be able to pin-point what did what, but I really like how it drives now, seems "sharper" and more controllable than before. Front wing is not finished yet, but at the speeds I did today, the front did not seem to lift.
The 1/5 TC GRP tires are a huge step up from the normal 1/8 truck tires, a lot of grip and car can accelerate quite quick now, found some pieces in the logs the car went from 25kph to 84kph in 1 second. That's an acceleration of 16 m/s^2, ~1.6 g, so 1.6 times faster than Mother Earth would accelerate it if being dropped from the rooftop . That comes with a lot of violence though, I was really impressed to see and hear the car working that hard, and the datalogs do scare me a bit - biggest recorded peak was 336 A, which made the 5Ah 60C Turnigy HD battery drop to 3.28 V/Cell. You can see in the logs it takes the batteriy about 7 seconds to recuperate from such a hit...
#29
Rebuilt front diff with new outdrives and 50-50 mix of 100k and 40k, so should be ~70k. Current diff setup (f-c-r): 70k-2000k-40k
126 gf/mm (7.06 lb/inch) Durango springs (65 mm front, 75 mm rear), and new bling-bling 3.0 front shocks. Filled shocks with 800 cSt fluid front and rear, should be around ~70WT, depending on brand.
Ltr: Losi 8ight-T 2.0 Rears, 3.0 Fronts (=buggy rears), 2.0 Front.
I think I need a white wing now too .
Saw the squares..must be the adapters...just wondering what all they will fit.
#30
