Help with motor mount
Not 100% sure what those are called (motor clamps I think), but they remind me of the motor mounts sometimes used in boats.
Hope this helps:
http://www.offshoreelectrics.com/pro...d=ose-80600-RC
Hope this helps:
Those particular motor clamps are from Fine Design, I'm not sure if they're still around or not. Another clamp style mount that is readily available is the one used in the HPI Savage Flux but I don't know it's exact inner diameter, 39mm maybe?
If you're looking for a LST motor mount I'd suggest checking out the mounts from RC-Monster or The Dude Racing. Both have more gearing options and since they use the motor's mounting plate can accommodate different diameter motors without having to buy a new mount. The. dude Racing mount is pricey but the RC-Monster mount shouldn't be much more than the clamp style ones.
http://www.servocity.com/html/motor_mounts.html
These might work.
I'd suggest making your own if you have the means. Cost me about $3 in aluminum and an hour of time.
Check post #65
http://www.ultimaterc.com/forums/sho...=188390&page=7
That's how I did mine. Works great.
These might work.
Check post #65
