nitro losi aftershock problems
I have a nitro losi aftershock I am trying to see what it is going to need to get running.
I started the engine fine but it was only turning the front wheels.
what do you think could be the problem? It is in the 2 speed gear box I do know that.
this truck needs a lot of work and I think this may be the bit that makes it not worth putting that much $$ in to it.
Check the set screw on the outdrive behind the transmission case. May have worked its way loose..
