muggy interchange
muggy interchange
does anybody know if the lst shock towers will work on my muggy looking to upgrade the towers to alum and have different mouting for the shocks. also is there anything that interchanges with the 8 buggy or truggy with my muggy looking for hop ups thanks.
LST towers will physically bolt onto the Muggy since the Muggy uses LST2 suspension. The problem the LST shock tower is taller and the Muggy shocks are shorter. Keep the LST towers with LST shocks.
Edit: The Muggy and the 8ight are totally different platforms and stuff doesn't interchange. The exceptions are the diff cups, outdrives, center diff and wheel hexes. The front ring and pinion from the 8ight may fit the Muggy diff cases but the ratio is different and I believe the bearings are different as well.
The aluminum inner bulkheads are long gone my friend....I've looked everywhere. Are you breaking them? It's the only I break on my muggy anymore, and I just keep a bunch of stock plastic ones handy.
One trick...that some might frown on...is to use a more aggressive threaded screw, like an old school traxxas Philips head thread, they hold better and although it will not be the original look, it holds up far better than those puny 3mm stock screws
If you find aluminum, please let me know....
