losi lst
losi lst
Question just bought 2 lsts for 200 bucks. One has a high low option on trans and reverse servo. And other has no high low option and no reverse servo. Is this OK or do I need to switch trans?
?kinda confused as to what you mean by this?
Have no hi low adjustment knob on transmission and no reverse either so have 3 servos in total compared to the other which has 4
Well yeah f you have no hi-low and no reverse then you only need three servos. I'm not really sure what your question is.
Is it just me or does Earl type just like he sounds with tobacco in his mouth? LOL Sorry to poke fun, but you do have to explain yourself better,
The truck with Hi/Low and reverse is likely an original LST or LST1. The other is likely a Aftershock. Hi/low is basically useless unless you're going to try and crawl the truck or do some sled pulling. Leave it in Hi and enjoy having the option of reverse when you need it. If your radio doesn't have the 3rd channel for reverse leave the servo in to keep the trans in forward. The only advantage the forward only trans has is that it is lighter with less rotational mass since it doesn't have all the Hi/Low and reverse gears. When the Hi/Low trans in Hi the gearing is the same as the other trans.
Before I begin I must spit lmao, but what you said makes perfect sense. It was one of those things that you can say it to yourself but elaborating it to others well fail.
