sizzling sound coming from my savage
when i shut the truck off theres a sizzling sound like its realy hot is this normal
sounds to lean.
I have the same sound coming from my OS18. I am running around 245 degrees and the sounds is still there.
reply
will i do any harm to motor ive just got it to do wheeles and it runs fing im
just worred about doing some damage to the motor
Try and avoid doing a donut for a long period of time.This overheats the motor quickly.Richen out the HSN also.
Sean
Sean
It should pull wheelies but you really need a temp gun to know how hot it is
getting, better to be safe than sorry. richen the high just a tick.
replyu
i dont even know if its tune right every ten minutes i go a 8th learner and it runs fine i only notice when i turn it off
The Boiling sound you can hear does suggest that your engine is on the hot side, but mine sometimes makes that sound - and it's still going strong after nearly 18 months and 2 porting jobs.
Just make sure that you can see smoke when the engine revs. Also, try putting some spit on the cylinder head - if it vapourises straight away, your engine is too hot. If it bubbles for a few seconds before drying off, it's about right. If it sit's there and does nothing, you probably forgot to start the engine first!!
Hope this helps.
reply
theres a lot of smoke especliy when I start her up
(it sounds like it could be coming from the muffler and its like you put some water on it when its hot
Oh!!! i might know!!! are you running rich? i have had this with my savage before,and i figured it out! sort of. here are three thing i have found that make that noise/sizzle
1 - loose glow plug - lets fuel leak out, and evaporate/sizzle
2 - fuel spill on engine/ engine mount - it, again, causes fuel to evaporate/burn, causing sizzling
3 - FIRE IN THE EXAUST!!! - happens if too rich, unburned fuel gets in pipe, floods up, and then catches on fire ( inside the pipe ) i learned this one when turning my engine off by putting my finger on the exaust, infact, i still am wearing the band aid... lol
so, tighten the plugs, dont spill, dont run too rich, and the sizzleing will go away, hopefully.
happy racing/climbing!!!
