Problems with Integy ulkhead on s-maxx..Help plz
I wreaked my smaxx into a metal clothesline post at WOT, broke the front bulkhead and bent some screws,and broke the plastic shock ends. I ordered a set of Integy Type II front bulkheads and installed them onto the truck, then I noticed that my front shock tower was leaning toward the rear of the truck alittle. I have taken the truck apart and reinstalled them to make sure I did it right, with no luck, thought that I may have bent the chassis, ordered a harecore titanium chassis and installed it...shock towers are still not pointing straight up ..anyone know what it could be?? I'm stumped. Thanks
Well being an aftermarket piece it was probably designed to sit back more then the stock piece to give you the lowest CF possible.
Sean
Sean
The kickup angle in the front is normal, there is nothing wrong with your truck.
thanks for the replays...thought that I had to spend more $$ LOL
