Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 11-08-2013, 04:17 PM   #16
I checked them over and I was missing a rubber inside the cap. All fixed now. There nice and bouncy. thanks for the help everyone
buddy92 is offline   Reply With Quote
Old 11-08-2013, 06:02 PM   #17
ThePanda's Avatar
Trader Rating: 64 (100%+)
Originally Posted by ThePanda View Post
Did you remember that there is an oring that fits into the top of the cap?
As for ride height, use the adjusters on the shock body, twist them down.
A-ha! I Knew it!
ThePanda is offline   Reply With Quote
Old 11-09-2013, 05:27 AM   #18
Spoke to soon. They have gone saggy again.
I have re-checked again and it's lost half it's oil again, this time using 40wt.
Not sure what's going on, I've rechecked the build and it's built correct from what I'm seeing.
Checked all rubbers, all are in there correct spots, no splits, none missing.
Stupid little hole!!!!
When I press them when filling them up to remove the air bubbles, if I do it firm enough the oil goes flying that much I hit the roof, and It's not that hard when I press them. Maybe that's happening in bumps and it's making it go out the hole, or out the bottom?
Old 11-09-2013, 05:43 AM   #19
Upbasher's Avatar
I know you said all the or rings were in place, but the bottom part of the shock body is critically important, all those o rings have to be perfect other wise the oil will leak out and run down the shafts.
About the hole on the cap, I've never heard of that on a savage. Try putting screws in them
I've been informed its against the rules to post things for sale in my signature.
Upbasher is offline   Reply With Quote
Old 11-09-2013, 05:44 AM   #20
The holes are tiny, I don't think I can fit one, but I suppose I can MAKE it fit?
The hole is literally pin sized.
I'll reseat the O rings on the bottom, there is 2 O rings on the bottom section.
Old 11-09-2013, 06:29 AM   #21
Upbasher's Avatar
Yep those two o rings are very important.
If you find a small enough screw you can probably make it fit. Maybe post pics so we have a better idea of what we're dealing with here
Old 11-09-2013, 09:53 PM   #22
I just woke up, I'll take some pictures shortly and post them up.
Old 11-09-2013, 10:28 PM   #23
ThePanda's Avatar
Try reading this it might help.
http://www.competitionx.com/rc-blog-...art-10-shocks/
The little hole is supposed to be there. It is a bleeder hole, just a different design than the one used on most shocks. The tlr 22 kit uses the same type out of the box.
Old 11-09-2013, 10:32 PM   #24
Awesome, thankyou very much. I will pull them apart and follow that from the beginning, hopefully have working shocks at the end of it!
Old 11-10-2013, 09:08 PM   #25
All washed, rubbers in wax an grease remover. Now to wait for them to dry completely
Old 11-11-2013, 07:51 AM   #26
i was going to ask if the bladder was in right way up but i dont see any in your pic?
Flux4.6version is offline   Reply With Quote
Old 11-11-2013, 03:33 PM   #27
Stupid question, but what's a bladder look like?
I have put them together, a tiny bit of oil come out, but I kept pressing them in for a few minutes and no oil is coming out, and it's a nice smooth springy movement now.
Old 11-11-2013, 03:38 PM   #28
Markcuda's Avatar
Shock bladders.
They go under the shock caps.
Team Associated Rival 1/8 Scale Monster Truck|Powerlab6|Junsi S1200
2 HPI Vorza's,One For Me,One For The Wife|FMA Parallel Board.
Losi XXL Nitro Monster Truck|1996 Thunder Tiger Mirage Pro.21|Kyosho Inferno GT2 VE Race Spec 1/8 scale Corvette C6-R ReadySet Electric.
Markcuda is offline   Reply With Quote
Old 11-11-2013, 03:45 PM   #29
ThePanda's Avatar
Originally Posted by Markcuda View Post
Shock bladders.
the xs ss uses emulsion style shocks, no bladders.
HTML code is On
