REVO ON_ROAD RACING
REVO ON_ROAD RACING
Hey guys just wondering weather or not any Revo/Monster truck guys run onroad pavement racing? The reason i ask is, up here in Canada (well in my club that is) its the coolest thing to watch!
anyone have any on road set-ups or tips?
Edward
Edward
If you race onroad....get the proline roadrages. I use the foams that have the stiff outer rings with them. Very little tire side roll with them. If you put limiters in the shocks you'll get a better center of gravity. I use plastic tubing made for ice maker supply line that you can get from the hardware store. It only takes between 1/4" to 3/8" pieces in each shock to lower the ride height. Be sure to use the same length piece in each shock. Get the shift point to get to second gear a little fast than you would for dirt. The tires hook up a lot better and in my opinion without the tire spin you have to shift a little faster. If there isn't a body requirement....heheheh get a sedan body to cut down on wind resistance. The stock body isn't to bad or the crowd pleaser bodies either however.... on a breezy day you'll notice a difference in the corners. That breeze can tip you over in the corners.
I use the proline Corvette body. It fits pretty good. Here's a pic.
Hey, I run a Revo also onroad. I found that the stiffest springs, proline 40 series bow ties and 80wt. shock oil work awesome. For added grip i zip tie the suspension down just a little, still leaving some travel to absord. I also have a lot of camber in the front and rear
acaddude, what tires are those? are they pretty good for onroad?
Those are the Proline RoadRages. There real good for pavement. The only other onroad tire I would consider would be the 40 series RoadRages. There wider with the same tread pattern. Some people like the 40 series. I personally think the ones I have are just right for me. I use HPI rims. The P3 rockers are a good fairly low cost upgrade for onroad that ogreasurada mentioned.
