Emaxx mamba monster problem!
#31
So has the slipper been tightened down yet?
#32
#33
Heres a video link. I have to appologize for the bit of shaking, hard to record and control at the same time. And for some weird reason it came out upside down.
http://www.youtube.com/watch?v=8LYnq8aQ1Go
#34
I was trying to watch the video, but being upside down hurt my head too much. The motor does not sound right. Also, is the esc fan running after that little bit of throttle? My fan doesn't come on for very long and I'm running 6s in a much heavier truck. Post a video of top speed with the camera right side up.
#35
I don't know for sure but it almost looks under geared. The only other thing I can suggest is to use an older version of firmware. 3.6 or something. If that doesn't work, send the video to castle, I am sure they have more knowledge on the subject. Good luck. It will haul butt when you get it straightened out.
#36
#37
What gearing would you suggest? Theres a 65t spur and I have a 28t and 17t pinion. Right now I've got 28/65 and shes flipping everywhere. I must say its pretty cool how much power the rig has but Id like to be able to gear it to somewhat control it.
Also I noticed that when going forward and I apply brake its ike a cracking noise. Is that normal for this ?
#39
There is no gearing that will help keep the wheels on the ground, you need to learn how to operate the throttle or adjust the power output with the castle link.
#40
It wasn't at the time.. I tried reversing throttle like the manual said. Anyway its working now.
#41
I'll try and get a video for you guys to hear it.
#42
What do you think ?
http://www.youtube.com/watch?v=03OClJq0G0E
#44
Its either your diffs or your spur. Post a picture of your spur gear.
#45
