Kyosho Giga Crusher OPT Force
Anyone with a Giga Crusher?
Well, Kyosho has a new version for Spring 2005!
Quote from kyosho.co.jp:
The spectacular speed and power of the popular twin-engine Giga Crusher DF has just been upgraded with special specification parts in the new "OPT Force" !
The special blue anodized aluminum parts can be seen throughout the machine, so it not only runs tough, it looks cool as well. The wider tread gives increased stability and precision shocks contribute to increased agility. Also represents great value when compared to individual purchase of special parts included!
The race for more power and speed just took a turbo boost!
* Blue Anodized Special Aluminum Parts
?@ Specially polished blue anodized Main Chassis, Sub-Chassis, Shock Stay, Suspension Plate, Steering Plate, Under Guard, Engine Mount, Cross Member, Servo Saver Spacer, and SP Shock Pivots.
* Turbo Big Shocks-L included
Equipped with Turbo Big Shocks-L for higher precision function and even smoother movement. Excellent surface tracing and damping effect produces greatly improved running performance.
* Wider Tread
?@ Specially equipped with plated wheels and tires that result in wider tread for increased running stability.
Front-mid mounting of twin GS26 engines fitted with recoil starters.
3-speed automatic transmission and center divided shaft driven 4WD.
Can even operate in reverse with 3-channel radio.
Equipped with newly designed air scoop with built-in air cleaner for stable engine revolution.
All main parts are factory assembled such as 3-speed transmission, diff gears, reverse transmission and engine/clutch section.
Opinion/s, anyone?
* Wider Tread
Opinion/s, anyone?
