HELP Marrying a Summit with a Mad Force Kruiser
So I am thinking about taking the Brushless Orion system from my Mad Force and sticking it into my Summit. My Question is what is going to break or need to be reinforced?
Thanks John
Thanks John
I have the mmm2200kv setup in my summit and the only thing i ever have problem with is the stock axles... As long as you dont try shifting low to high or vice versa you wont have problems with tranny.. Also dont lock the diffs while moving either and you wont have any problems.. be prepared for some serious increase and speed.. I would recommend a tire upgrade also if your running stockers cuz the stock ones cant handle much speed
I also forgot to mention stock clutch lasted about 15mins on my setup.. So i would recommend the hd clutch traxxas offers...Havent had a problem with it yet..
So you can shift low to high and lock and unlock, just not while running correct?
i will look for the Traxxas HD clutch. Thanks.
