Savage steering issue
G'day, apoligies if this has come up before...i searched for an answer but cant find. Im having trouble with my truck only turning one way, when i disconect the horn everything seems to be fine when i move back and forth by hand. When the horn is connected it turns both ways but only steers one way...just doesnt seem to push the wheels back the other.
Cheers.
Cheers.
Also make sure your servo saver spring hasn't loosened up, with the truck on the ground watch to see if the servo saver gives instead of turning the wheels.
disconnect the servo horn, turn the radio on and reinstall in the centered position, making sure your trims are at zero. and check the spring like slayer said
Splines should be good to go, its a new horn..but will check for sure tomoz.
Im thinking it has something to do with this...i didnt even know what a servo saver was/is/does, i googled it and i think i did adjust the purple colored screw...but know no matter where i adjust too...it doesnt turn the wheels one way was going to order another one as they arnt that expensive.
pretty sure this isnt the prob as the horn was/is centred.
BIG THANKS! for your suggestions in helping me out guys....much appreaciated, cheers.
If all is good, swap your existing servo saver spring to this.
http://www.google.com.sg/url?sa=t&rc...iXWiJ_Z4A0VXHQ
Even a 50kg torque servo cannot turn well when the servo saver spring is soft.
What the saver does is when you crash or run into something it gives and lets the one V part ride up the other so the force isn't directly transferred into the servo or horn.
