tmaxx 3.3
tmaxx 3.3
I have a tmaxx 3.3 runs good love the truck but the wheels wobble like crazy why do they do that it is like brand new never wrecked it. I thought it was the pivot ball cups that was too tight but i dont know can somebody help me.
i tightened the ball cups up and everything but they still wobble so what is the problem
Have you checked the carrier bearings, the hinge pins, A-arms for cracks, bulk head for cracks, slop in the rod ends, slop in any bolts ETC, ETC? Bearing carriers like to become slopy, the stock plastic is weak with no "memory" if you will..... once bent it will stay bent giving you bearing slop. Got to love traxxsucks
As for the pivot ball retainers, I like to take the shocks off to check movement for binding while tightening. You want the retainers as tight as you can get them with the least amount of binding. I like to lightly coat the balls with white lithium grease as well.
