Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 05-10-2012, 12:23 AM   #1
Bighomedog11's Avatar
Send a message via AIM to Bighomedog11 Send a message via Yahoo to Bighomedog11
Default Inside of Motor
Hey I took my motor apart to seal it. I had found some Permatex Black Sealant in my tool box so i used that.. I also took some pictures of the inside of my piston.. Tell me what you guys think..
Bighomedog11 is offline   Reply With Quote
Old 05-10-2012, 03:54 AM   #2
Trader Rating: 24 (100%+)
Looks burnt, gooey, crispy, black and brown creamy with a touch of crusty all rolled together in one. It also looks used, betrayed, abused, R/C raped and skull punched.
Engines should look happy! Lightly brown toasted on the top with no black and brown drippings mixed in and running down the side. Neat, clean shaving, well mannered and groomed properly are a must for a happy engine. A happy engine screams MOXIE!
.......__________________
....../_==o;;;;;;;;__ _____]
.....), ---.(_(__)
....//___// Support NRA!
got_nitro is offline   Reply With Quote
Old 05-10-2012, 10:05 AM   #3
My engine is not black it is brown, Just hard to tell in the pixs. Also i have ran about 2 gallons threw the engine and it still runs strong.. But i am getting close to a rebuild soon..
Old 05-10-2012, 01:04 PM   #4
That engine looks like it has a 55 gallon drum ran through it.
Since it's out of the truck and really, you only pulled the head off and did a quick wipe, why stop there? Pull the header off, Pull the back plate off, pull the sleeve and piston out, pull the crank and clean that thing up.
Can't help but notice the piston in TDC, usually if a sleeve has pinch left, the sleeve would pop out of the block before the piston gets to TDC. That mill looks spent to be honest....
.....), ---.(_(__)
Old 05-11-2012, 05:57 PM   #5
For all intensive purposes it could be purple, green, red, or black it really doesnt matter. Dark colors mean lean settings. You could have 3-4 gallons thru it and if properly tuned it should only be a gold color. +1 on TDC. I hope you had to push it up that far. If not IMO your in need of either a repinch or rebuild
Phins Fan is offline   Reply With Quote
Old 05-11-2012, 07:32 PM   #6
SLAYERDUDE's Avatar
As an example here's my HPI K5.9 @ 9 gallons, it's now on gallon #13.
And here's how much pinch there was-
This is at 6 gallons -
HB ERCM D8T, Savage XL, MGT 8.0, AE RC10GT's, HPI MT1, AE RC10's T3 B3, the list goes on...
SLAYERDUDE is offline   Reply With Quote
Old 05-11-2012, 10:38 PM   #7
Yeah i pushed it up that far just for the picture. But I am going to run my engine more rich because it still runs good.. I just need to run it more rich now. Then when i rebuild i will make sure to tune it better
xxxt losi melting inside of diff gear? adawg1 Electric Off-Road 14 11-15-2008 07:59 PM
The Inside of a Battery rcguy2477 Electric On-Road 23 05-03-2006 05:33 PM
The next evolution of Motor cooling micros_rock R/C Items: For Sale/Trade 19 08-26-2005 11:44 AM
HTML code is On
