Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 05-08-2012, 05:18 PM   #46
The Pope NJ's Avatar
Trader Rating: 1 (67%+)
Trx motors work the same as any other motor. It is stupid to believe that a fuel that doesn't work in anything else would somehow work diffrent in those motors. End of the day run what you want. It is a simple fact that the quality of the lub in it and the level of it just is not ideal for nitro motors. And the quality control one gallon to the next just isn't consistent.
I challenge everyone running trx fuel to pick up a gallon of Byron's and see for yourself. Now if you can't tune a motor it won't much matter but if you can once you go Byron's you will never run anything else.
Speeds just a matter of money; How fast you want to go?
Home site www.HPISavageForum.com
Youtube user: ThePopeNJ
The Pope NJ is offline   Reply With Quote
Old 05-08-2012, 08:06 PM   #47
Graveyard's Avatar
which type of byron fuel are you using? I've never used anything but 20% traxxas fuel.
Graveyard is offline   Reply With Quote
Old 05-08-2012, 08:35 PM   #48
ckblood05's Avatar
Trader Rating: 15 (100%+)
i run the gen-2 20% 12% oil byron's.
traxxas t-maxx 3.3 model#4908 hopped up from the ground up!!!!!!!
duratrax 1/18 mini quake 4wd every part is upgraded!!!!!!!!!!
trinity spyder 4wd. 1/18 stock
ckblood05 is offline   Reply With Quote
Old 05-08-2012, 08:39 PM   #49
I run Byron's 2500 pro driver 25%nitro 9% oil
Old 05-08-2012, 10:45 PM   #50
SLAYERDUDE's Avatar
Originally Posted by Maximo View Post
Speed is not a sensitive to this, and the power is modest compared to the modifieds we run..... a engine like my P5 is substantially faster with a much stronger crankcase vacuum........... Speed blend is not a suitable fuel for engines like my modifieds, too thin and unable to make a proper seal in the crankcase
Would adding a couple ounces of Klotz Benol to the O'Donnells 30% Speed blend be adequate?
I'm a longtime Byrons fan, but I can only get OD Speed Blend now, but I also have Klotz...
HB ERCM D8T, Savage XL, MGT 8.0, AE RC10GT's, HPI MT1, AE RC10's T3 B3, the list goes on...
SLAYERDUDE is offline   Reply With Quote
Old 05-08-2012, 11:33 PM   #51
Bighomedog11's Avatar
Send a message via AIM to Bighomedog11 Send a message via Yahoo to Bighomedog11
I know this is off topic but is the Eliminator fuel not good by Wild Cat? 20% Because i been using that buy reading this makes me want to switch to TRX fuel
Bighomedog11 is offline   Reply With Quote
Old 05-08-2012, 11:45 PM   #52
SLAYERDUDE's Avatar
Lol don't use Crapxxas fuel, EVERY engine that's been given to me that had Crapxxas in it was a pile of corroded nasty sludgy junk.
Wild Cat I believe is made by Morgans, same as Sidewinder, heard that's good stuff.
I'd only use Crapxxas fuel to clean air filters, but they might get clogged too.
BTW- every fuel tank I got that had Crapxxas was a clogged mess of nastyness also.
Old 05-08-2012, 11:51 PM   #53
I guess I will keep using what i am using, Because i havent notice any problems with it but i never tried a different fuel before though. Yeah i think it is made by Morgans
Old 05-08-2012, 11:52 PM   #54
ckblood05's Avatar
yea after this quart of 20% eliminator fuel, im going back to 20% byron's.
Old 05-08-2012, 11:55 PM   #55
I think i am going to stick with eliminator because i notice i haven't had to change my glow plug yet and i had this one in for a few months now. I also use After run oil so my engine should be looking good inside.
Old 05-09-2012, 12:02 AM   #56
ckblood05's Avatar
yea as far as when im going to get a quart, i will probably stick with the eliminator. i will see how my t maxx runs when that spring comes for my fuel tank lid. i think it will be here tomorrow, but its supposed to rain. but thursday is looking good!
Old 05-09-2012, 12:11 AM   #57
SLAYERDUDE's Avatar
Here's after 6 gallons of Byrons in my HPI K5.9, the sludge rusty pics of the Crapxxas are in my other PB acct.
Might as well post the Crapxxas pics since that's what you guys want to see lol.
Old 05-09-2012, 12:49 AM   #58
Maximo's Avatar
that is a very good idea to do...bring it up 2% or better..........
http://www.thenitroshop.com/
Maximo is offline   Reply With Quote
Old 05-09-2012, 04:08 AM   #59
Trader Rating: 24 (100%+)
That tells me that werks is somewhere around 10% Whatever the case may be, both fuels we were talking about have ample amounts of caster/synthetic mix, just a matter of tune. Guys run all sorts of different race engines where I go, (moded, stock) and I'd say 90% of the fuel used out there is OD's speed. No one has problems with engines not getting enough lube or seal problems because of Speed blend fuel.
.......__________________
....../_==o;;;;;;;;__ _____]
.....), ---.(_(__)
....//___// Support NRA!
got_nitro is offline   Reply With Quote
Old 05-09-2012, 09:20 AM   #60
Maximo's Avatar
that is not accurate at all..
Werks is not 10%.....its probably similar % wise to Speed Blend
Werks uses a very different lubricant, that is also very good, so it does not need to have its oil content raised.........
The lubricants used in OD Speed blend and Werks are night and day different...OD is very dry with no residulal lubrication...Werks is very wet, with huge amounts of residual lubrication..OD lubricant all burns off, Werks does not
The only advanatge OD has over Werks is its easier to find , Werks is the better product of the two......
here is what the inside of a engine running Werks looks like... this fuel has almost zero smoke when it runs, the oil does not burn off like other fuels, instead the oil sticks around and lubricates and seals the engine... Thiese pics are days after running the engine, the oil is thick and sticky like airfilter oil............
how to make nitro fuel Trail Bruizer Offroad Nitro Engine Forum 17 04-08-2016 04:24 PM
nitro fuel poll requested by "jamminkrazy" J.Whiting Offroad Nitro Engine Forum 96 12-18-2010 10:25 PM
What is your favorite Nitro fuel? kodiakbear7070 Nitro Off-Road 75 11-10-2009 08:57 PM
Nitro Fuel Pric Increase ? fastrcracer Nitro On-Road 58 07-17-2008 07:56 AM
Nitro Fuel shortage? nitrothugg Nitro On-Road 28 06-04-2008 09:06 PM
HTML code is On
