Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 04-30-2012, 08:25 PM   #1
Bighomedog11's Avatar
Send a message via AIM to Bighomedog11 Send a message via Yahoo to Bighomedog11
Default Tmaxx Slipping Clutch
Hey for some reason i notice that my clutch would sometimes slip. I have tighten my spur gear all the way then back off 1/8 of a turn and it still slips. I am wondering why is it doing this. I got friction pegs in all 12 holes. I also had changed my motor to a 3.3 it was oringal the 2.5 but i did that awhile back and never had any problems. I am trying to figure out why is it slipping.
I also notice when i pull the string to start it. It feels like it is slipping and not turning the engine sometimes.
Bighomedog11 is offline   Reply With Quote
Old 04-30-2012, 10:10 PM   #2
ckblood05's Avatar
Trader Rating: 15 (100%+)
its probably your one way bearing in the pull start. try taking it out and cleaning it. are the friction pegs wore down?
traxxas t-maxx 3.3 model#4908 hopped up from the ground up!!!!!!!
duratrax 1/18 mini quake 4wd every part is upgraded!!!!!!!!!!
trinity spyder 4wd. 1/18 stock
ckblood05 is offline   Reply With Quote
Old 04-30-2012, 10:11 PM   #3
cdewalt1985's Avatar
Trader Rating: 17 (100%+)
also check clutch spring isnt broken
HPI Baja 5B/T Conversion 27cc cy Traxxas Slayer Pro 4x4 3.3
HPI Baja 5B 27cc ZN Traxxas Tmaxx 4x4 3.3
HPI Baja 5B 27cc ZN Pro Mod
KM Ksrc002 30cc
cdewalt1985 is offline   Reply With Quote
Old 04-30-2012, 10:15 PM   #4
ckblood05's Avatar
yea i would take your clutch apart and check it out.
Old 05-01-2012, 12:14 AM   #5
The friction pegs are flat on the spur gear now. They could be worn down because i havent changed them in a few months now. My clutch should be good because i just recently changed the clutch out..
And the one way bearing that is only effecting the pull-start correct? That is not effecting the slipping i am getting from the clutch? And what whats the best way to clean the one-way bearing
Old 05-01-2012, 12:12 PM   #6
ckblood05's Avatar
yea the one way bearing will only effect the pull start.The best way to clean it out is to take it apart and spray it down with some kind of degreaser and lightly oil it with some bearing oil. just make sure when you put it back in the text writing on the one side is facing the engine.
Old 05-01-2012, 02:22 PM   #7
Alright will do, how about the clutch slipping? Could that be because my friction pegs are flat? How fast do friction pegs wear out
Old 05-01-2012, 02:54 PM   #8
ckblood05's Avatar
im not sure about the pegs? my t maxx uses a disc not pegs. im using a robinson racing spur gear and slipper pad.
Old 05-01-2012, 03:11 PM   #9
Oh my max has a spur gear with the friction pegs inside it.. stock setup.. I'm just going to change the pegs and see what happens.
Old 05-01-2012, 03:44 PM   #10
ckblood05's Avatar
yea i would, see if that helps out.
Old 05-01-2012, 03:57 PM   #11
I will you let know if it fixes or not. I am thinkin about just takin my engine off and cleaning it and sealing it. Because I also notice I have a hard time setting the idle.
Old 05-01-2012, 04:20 PM   #12
ckblood05's Avatar
yea i would seal it up. ok, yea let us know how it works out for ya!
Old 05-02-2012, 01:48 PM   #13
I bought some new pegs today and i notice that it fixed my problem. I am going to eventually upgrade clutch once this wear out..
Old 05-02-2012, 04:14 PM   #14
ckblood05's Avatar
sweet! thats good to hear
Old 05-02-2012, 05:49 PM   #15
Yepp now my brakes went out. I need to get new brake pads now..
Adelaide Nitro Offroad Racing Club oblivion Australian Racing 19736 01-14-2017 02:12 AM
.15 tmaxx questions.. AlanHall Monster Trucks 10 08-29-2008 04:32 AM
HTML code is On
