2.5R to 3.3 Revo Conversion Questions
no it requires just a few extra pieces. You will need longer steering linkage, and you will also need the extended front center drive shaft as thats where they added the extra length on the chassis. If you look at the chassis you will see the gap between the shock mounts and the transmission is bigger on the 3.3 chassis.Let me see if I can find the exact part numbers. I just did mine like 2 months ago it was a bit of work just as it's a lot of stuff to take a part. But It was fun to learn the truck inside and out a little better. Over all pretty easy though. One thing I can recommend is to buy a extra set of screws and hardware off of ebay. I got an extra set of screws and tools for like 10.00 and let me tell you it was worth every single penny. Made the conversion 10x easier for me. Not having to make sure I kept every single screw in the right spot.
5322x is the 3.3 chassis
5456 is the front drive line
5341 is the steering linkage
