What's the trick to beefing up rear turnbuckle on the MGT 8.0
What's the trick to beefing up rear turnbuckle on the MGT 8.0 , when ever I don't land right from a jump or do a back flip the ball end breaks off the rear turnbuckle.
Thanks for your help
hard to belive no on this forum has any idea's on this matter
I never had that issue with my MGT when I had it. Mine always broke the carrier side of the turn buckle. I used a higher viscosity shock oil and it slowed down the compression of the shock. Also make sure that you have enough fluid in the shocks so there isn't any slack. I used a combination of red and blue springs with varying width spacers as well at times.
Lol, I read this yesterday and never realized it was your thread Doug.
I guess if I figure something out you'll be the first to know!
I'm gonna see if Savage turnbuckle ends will work, as I think you are going to as well.
Melonpeel - we's talkin about the turnbuckle ends, and anyone that's getting the RPM knuckles take note that you need RPM pivot ball retainers and bearings & spacer also.
http://www.youtube.com/watch?v=Uc7UtlvwdzU
+ YouTube Video | |
i know the mgt looks very much like a tmaxx. i dont know if it is possible to mod some rpm true trac arms. the true trac arms do not use rod ends. it comes with a fixed arrier.
http://www.rpmrcproducts.com/product...s/maxxpts3.htm
all most forgot about this thread LOL , yep its me Tom , rebuild (Doug) LOL ,
true track I'll look into that ,but is'nt the T-max 1/10 scale , may be to small to fit the MGT 8.0 , time to do some home work
