Savage XL - Three Speed Tranny
My savage XL won't shift into third gear... I have turned the allen screw inside the transmission counter clockwise to get earlier gear shift but it still will not shift into third... Is there something else I could do to get the transmission to shift?
it shifts into 2nd perfectly but then it seems like it wants to shift to third but just doesn't so it might need a good tuning of the engine because I haven't done that in a while. could that be the problem??
Try turning the 2 - 3 shift in first, far in, keep on going. Do at least 5 turns in from flush to start, then make 1/8 at a time, & adjustments from there.. If your shift disappears, your too geared down, & you can either run bigger wheels, gear up, or adjust your shifts to match.
With the shift missing (after completing the suggested test) turn in your your 1 - 2 shift until you get a clear shift, & then adjust it accordingly, then once you have the 1 - 2, try and catch third, if it don't grab, dial it back
tune
hows your tune? if your engine does not have enough scream, it may hit 2 but not enough to punch into 3rd. if that is not the case, if you already tried to the max adjusting the 3rd, open your transmission and check out the 3rd gear binding
