Wallee's T-Maxx Build!
#46
Yep, found this for ya
#47
An E-clip will work, but a 3mm button head (or cap head if you have the room) screw with a small dab of locktite is almost foolproof.
#48
The E-Clip comes factory. I kind of like the E-Clip for the fact that you dont have to worry as much about the shimming since there is less play, and you also dont have to worry about stripping a bolt... I dont use loctite on my clutch bell bolts for that reason...
#49
Where am I going to find a new eclip though?
#50
#51
#52
#53
Thank you so much! Just have to get it ordered now and here.... Sometimes the wait is annoying but worth it in the end I guess ha ha.
#54
You can use a 3mm bolt if you dont have an e-clip. Either will work fine. You may need some shims with a bolt though.
You might consider this while you are shopping. It saves a LOT of trouble if you do much clutch bell or engine swapping:
http://www3.towerhobbies.com/cgi-bin...?&I=LXNT03&P=M
#55
I will look into that as well, Not sure which I will go with yet. Seems to me like the e-clip came off way to easy and it will probably do it again...
#56
Got the new slipper clutch installed last night, now how tight should it be?
#58
#59
