LST2 GEARING
LST2 GEARING
I have a lst2 with a mmm/1800kv they are castles, i need some help with the gearing it is runing 25t p and 62 spur the speed is good but at this gearing it has burned 2 of the castle mmm up. I run it on 4s turnigy 30c.
Some help please and thanks.
if it were me Id run no less than 6s lipos with that truck. What is the motor exactly? 1515 1520 1521???
It should need 6s. The savage flux gets by with 4s fine, and so does my MGT with a hobbyking brushless setup.
Are your batteries rated good? Batteries without enough amperage may be hard on the ESC. What is the motor heat like?
My lipos check good the motor is the1518/1y 1800kv temp is 150 to 165 that is way i wont to gear down and on 4s this thing will fly and will do back filps.
And i wont to gear down to take from the amp drow so if this helps i dont know much about gaering so i am asking for help with that as for the pinion and spur.
Thanks kevin
Thanks kevin
