grease in gear?
grease in gear?
Hello,
I am brand new to RC. I am trying to fix an Emaxx for my kid. Upon opening the gear box, the plastic cover in front of the twin motors, I found no grease in the gears. It is necessary to have a little grease in the gears? thanks.
I am sure I will be back for lots more questions.
Jeff
Jeff
yes there should be some lubrication in there for longevity sake
Hello,
Jeff
Jeff
Umm, NO! Do not run any grease on your spur or pinion gears. Those should be run DRY.
+1 on no lube or grease on your spur and pinion gears.
My RTR MT came from the factory with no grease so I figured that the it's not required. I also recall reading somewhere (may have been in my MT's manual) that you don't lube up those gears.
Coming from playing with big cars in my youth, I was thinking all gears need grease. Guess not, thanks. Almost smear a whole bunch on there this morning.
