Revos 3.3 help
Revos 3.3 help
I have heard a lot about this forum and I am new to the traxxas. I have a revo 3.3 and I am at a loss as to what to do. Any ideas please let me. Below are the details. When I give it gas it just revs up, will not move. I have replaced the pads on the back of the slipper clutch. I then checked the transmission and had some teeth missing off one of the gears. So I replaced the gear and its still doing the same thing. I have tightened and loosened the slipper clutch and still nothing. Any suggestions?
Thanks for any help
Jerod cross
Thanks for any help
Jerod cross
Did you tighten the slipper all the way? And when you say you give it gas are you WOT and it still doesn't move? What are you noticing with the slipper and the gears/flywheel when you give it gas?
it could be your drive shaft
All the way from quarter throttle to wide open. I have tightened slipper clutch as tight as I can get it. The fly wheel is turning and also the slipper clutch is turning. What should i check on the drive shaft?
I have had the exact same problem. I tore the transmission apart. In the transmission there was a bearing melted into one of the gears the ratio gear it was. I replaced that and I had to a pin in the transmission. It has gone back to working correctly since I made these repairs. It took me probably two months to finally figure out the problem though. I tore up a few spur gears, few pins, and a few forward gears in the process. But I recommend doing a full tear down on the transmission if you checked everything else or you will end up ripping all your hair out.
I have had the exact same problem. I tore the transmission apart. In the transmission there was a bearing melted into one of the gears the ratio gear it was. I replaced that and I had to a pin in the transmission. It has gone back to working correctly since I made these repairs. It took me probably two months to finally figure out the problem though. I tore up a few spur gears, and a few forward gears in the process. But I recommend doing a full tear down on the transmission if you checked everything else.
will does you model still have reverse in it. cause if it does the pin that hold the reverse gear does break sometimes. Will when it break it will not hold the foward gear in place so the whole primary shaft will just spin around the gears. the reverse gear holds the forward gear in place on the primary shaft and the pin holds the revese gear in place. i woul do just like the other guy said and take a look at the whole tranny. best off luck to ya
I have the exact same problem i already sent i back traxxas looked in to it replaced spur gear got it in yesterday and tried breaking it in and did the same thing i havent even finished breaking it in i think the revo is the worst truck ive had nothing compared to the rustler and much less to the jato 3.3 .....revo sux
It might be bad luck but its to expensive for not to work im sorry guys but i think its a piece of crap truck
Just take the time to fix it. They are easy to work on if it breaks. Sometimes things do break when for others they don't. It doesn't make it a crappy truck. Instead of giving up and complaining learn how to fix the issue.
Can anyone tell me how to get the two screws back into the header on traxxas 3.3/ The way the top screw on the header goes in right behind the curve of the pipe I can' seem to get the screw in at a 90 degree angle when I try to put it in at an angle it only goes half way in? Im sure this is an easy solution but I can't figure it out lol. I bought a new resonator and can't get it or my blue pipe back on lol, I knew when I took the top screw out of the header it was going to be a nightmare to get back in.
