Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 12-17-2011, 06:26 PM   #1
moondoggie's Avatar
Trader Rating: 30 (100%+)
Default Brushless Emaxx FLM Build/ Advice Thread
Okay so i traded a short course roller for the emaxx roller and have since put on a hobbyking 120amp esc and turnigy 2200kv motor. Took it out to begin with and this thing rips, I am having blast with it. Did a little bashing and ended up breaking the rear bulkheads, a shock, and destroying a diff. So i rebuilt the diff and put aluminum bulkheads on the rear which broke to begin with. Took it out to the skatepark today and did a couple of jumps and you know how it is when everyone is like ewww and awww you go bigger. Needless to say the rear bulks did there job and snapped the chassis bringing us to where we are at now.
here are a few pics
moondoggie is offline   Reply With Quote
Old 12-17-2011, 06:35 PM   #2
moondoggie's Avatar
Ok so i am looking for advice, i wan this truck to be a true basher and here is the list of parts i have in plan so far. Please give me your advice on anything and if you would change any parts i have picked out that have not been ordered.
Parts List
1. FLM Chassis (ordered)
2. FLM Hybrid bulheads
3. hyper 7 diffs
4. RC-Monster output shafts
5. new shocks (need advice)
6. drivetrain (need advice)
Please help steer me in the right direction to get it right the first time, the only thing that is set in stone at the moment is the chassis because i already ordered it. I could also use some help on the diffs, I have searched and read a lot but just wan to make sure i order everything i need at once so if somene has done this please chime in.
Old 12-18-2011, 03:43 AM   #3
Tekno axle carriers
Losi LST XXL cvd's
Traxxas E-Maxx: FLM Chassis, Shock Towers, Hybrid Bulks, 1/8th scale drivetrain, RPM A-Arms all the way around, Traxxas Tubes, RPM Bumpers, CC MMM ESC, CC MMM Motor Shroud, XeRun 4274 2000kv Motor, HiTec HS-7955TG Servo, Tekno Axle Carriers w/17mm hubs, UE RacerX SuperShocks, Proline Big Joes, Proline Tech 5 Rims, FlySky GTB-3 2.4ghz, Traxxas Single Motor Plate, Robinson Racing Gen3 E-Revo Slipper with Steel 65t Spur.
Mustang63 is offline   Reply With Quote
Old 12-18-2011, 06:02 AM   #4
moondoggie's Avatar
Originally Posted by Mustang63 View Post
Tekno axle carriers
Losi LST XXL cvd's
Can you give me a total parts list to convert it that way. I saw you had a post looking for some bearings to make it work. Also what diffs are you running and what cups did you go with on the diffs. Thanks for the help
Old 12-18-2011, 06:40 AM   #5
Get flm chassis
Flm hybrids
Hyper 7. Diff with ue outdrive cups
Cvds ft/rr(traxxas,mip,ue)(depends on what knuckles you have) with center cvds(traxxas)
4 or 8 ue shocks
ue-maxx is offline   Reply With Quote
Old 12-18-2011, 07:31 AM   #6
Suspended
Trader Rating: 25 (96%+)
Essential upgrades
FLM Chassis (http://www.fastlanemachine.net/prodd...lm10900&cat=15)
FLM Bulks Front and rear
(http://www.fastlanemachine.net/prodd...LM10300&cat=15)
(http://www.fastlanemachine.net/prodd...LM10200&cat=15)
FLM Diffs (
(http://www.fastlanemachine.net/prodd...LM13010&cat=15)
FLM Shocks (use stock internals )
(http://www.fastlanemachine.net/prodd...LM19100&cat=15)
That should give you a true basher and dont forget RPM arms
Lst2Man is offline   Reply With Quote
Old 12-18-2011, 10:54 AM   #7
moondoggie's Avatar
[QUOTE=Lst2Man;10052366]Essential upgrades
FLM Diffs (
you would use these diffs over the hybrids,do you have any experience with them because i have also looked that route but thought the 1/8 scale diffs would be overall stronger. Not doubting you in any way, thats what i want is thoughts, advice and actual experience. thanks
Old 12-18-2011, 10:59 AM   #8
http://www.teknorc.com/product_info....roducts_id=988
http://www.ebay.com/itm/2-LOSI-LST-X...item589016db2a
http://www3.towerhobbies.com/cgi-bin...?&I=LXSKU8&P=7
The bearings don't fit perfect but they work fine, also a washer between the hex and the axle carrier will take the slop out and I used the hyper 7 diffs as well and did not need the rcm cups that I bought
Old 12-18-2011, 11:31 AM   #9
moondoggie's Avatar
so did you just use the stock cups that came with the diffs, sorry for all the questions, i am going to order everything next week and just want some input to make sure i get it all at once.
Old 12-18-2011, 11:34 AM   #10
moondoggie's Avatar
Also what is your opinion on the aluminum arms are they just bling or will they last to some serious bashing.
Old 12-18-2011, 11:36 AM   #11
blazerss's Avatar
Trader Rating: 61 (100%+)
You won't be disappointed with the flm chassis. I have a basher truck with that chassis and it works great.
For shafts I run the traxxas cvd's and they have held up great.
For cups I run ue cups around the entire truck. They are the best you can buy IMO.
For diffs I run ue ultralites. There expensive and hard to find, but well worth it IMO.
If your going to upgrade the towers look at ue knuckle head towers. They are great and you can't beat the price on them.
Good luck with build and keep us updated.
blazerss is offline   Reply With Quote
Old 12-18-2011, 12:32 PM   #12
moondoggie's Avatar
any ideas on shocks, this truck will definatley see its fair share of 10ft or higher drop offs. i have a skatepark near by and am not afraid to send this thing a flying.
Old 12-18-2011, 01:51 PM   #13
Yep just used the stock cups that came on the diffs, my truck can take a serious beating, I hit a tree at full throttle on 5s and didnt break or bend a single thing
Old 12-18-2011, 01:51 PM   #14
blazerss's Avatar
Personally I run proline power strokes on mine, but i never bash it that hard and they are hard to come by. I have ran the traxxas big bores and they were surprisingly decent. My advice would be to stay away from integy shocks and the aluminum shocks you buy off eBay. I've had experience with most of them and they are just horrible shocks. Ue makes good shocks as well.
Old 12-18-2011, 01:53 PM   #15
If you get the UE Supershocks, I would also reccomend getting the UE Motherlode for spare shock parts
HTML code is On
