Losi Aftershock/LST
Losi Aftershock/LST
Hi, I'm new to this forum, but not new to R/C. I didn't see a "newbie" thread, I did a few searches, but I figured I would just post my ?.
I have a Losi Aftershock that I put the 454 and LST2 trans on. I broke it in, put about 2 tanks through it after break-in, it stalled, and when I tried to restart it, it was like starting in gear. When I crank the roto-start, the wheels turn with it. Would this be a one-way bearing issue? And why so soon after the first few tanks? Dirt?
JC
JC
Hey and welcome!!
My guess would be the clutch or your bearing that is where your clutch is at. I had that issue with my werks b3 pro. It would start and run bit when I hit the break it would die. Do you have that same problem?? I'm sure i could be wrong. I'm sure someone will chime in and help..
What they said. Its either bad clutch bearing(s), or a broken clutch spring. Pretty simple fix
