3.3 t-maxx teardown/rebuild!!!!
#32
here is a couple pics of the rear. i couldnt put the rear bumper mounts and rpm bumper on. before i had the stock grey bulks, now i got the aluminum integy bulks. the screws that holds the upper arms on are in the way of the bumper mounts to go on the end of the bulkhead. so i just put the rpm bulkhead brace in, i dont need a rear bumper. i mean after all, i dont have reverse,lol.
#33
It does, flipping the diff will make that set of wheel spin the other way. Look at the exploded drawings and be sure you have the diff oriented the same way as pictured.
Been more than one T/EMaxx when put back together, the truck will not more cause one diff was flipped.....
#34
#35
Front diff: The screws heads that hold the diff housing together should be on the right side looking at the diff from the front of the truck
Rear diff: The screws heads that hold the diff housing together should be on the right side looking at the diff from the rear of the truck.
#36
Not unless you get lucky…
#37
ok, i switched the front diff around. now its all good! i threw my brand new proline 40 series rims with my brand new proline 40 series bow ties on to see how it will look. and to adjust my camber and toe. the rear is already set because i put on the rpm true track suspension arms. have to say.....looks pretty sweet!!
#38
heres some pics of what it will look like when completed. everything is pretty much just setting there. but im not sure if its all going to work together? like with that aluminum fuel tank, the engine dont quite fit right. the 4 mounting holes for the engine, the tank is in the way for the engine to mount with them holes. so im going to have to mount the engine first, then put the tank on. the bottom of the tank will sit on top of the engine mount a little. and the tranny looks pretty tight. like the spur gear almost or might hit the tank or the battery box. i wont know for sure until i put everything in and tighten everything down. i hope i can get it all to work together because you gotta admit.....it looks pretty sweet!!!!! but i think i need more blue lol
#39
i thought now was a good time to go over my engine. i ordered a new header and gasket. when it comes, im going to use some permatex ultra black high temp rtv silicone to seal it. i just got done taking my one way bearing and i soaked it in dynamite magnum force 2 electric motor cleaner for about 15 minutes.then i dried it off and let it set in mobile-1 10w-30 oil for about 5 minutes. then wiped it off and put it back on with the pull starter. and i used the rtv silicone around the pull starter to seal it.
#40
Should have just ordered a THS full header and pipe. It would have woke up that trax mill. That rubber tip is robbin' HP too....
#41
well i did buy a full ths exhaust system, but it was for the .15 engine. i want a ths exhaust system! i just dont have the $$$$ right now. and you talking about my exhaust deflector? everyone runs them. how could that rob me of power? if i blow through the pipe, i can feel the same amount of air coming out as with it off. besides, it helps keep all that oil from getting all over the rear of my truck.
#42
i want this right here-
http://www.ebay.com/itm/NEW-Traxxas-...item2eb921b6ae
i just dont understand how the header will mount to my engine? i dont see a flange and the 2 holes for the screws to go into? plus the stock resonator pipe is bent to fit right. this is just straight......
#43
See the spring on the side of the block?
#44
Your pushing exhaust through more piping.
You don't use screws to mount it. It's a spring mount. There are 2 holes in the header flange, one U hook on the spring goes in one hole and the spring gets wrapped around the block and into the other hole in the flange on the other side of the header.
ok, yea i saw that longer spring in the kit. i figured it wrapped around the head. do them springs make for a good seal though? i need the pipe with the side exit stinger and not the one with it on the bottom of the pipe. im trying to make a offer to the guy selling the one i posted above^^^^^
#45
so these guys are really loosing power huh?
http://www.youtube.com/watch?v=v3KiVRim0rw
http://www.youtube.com/watch?v=ieE84...eature=related
http://www.youtube.com/watch?v=MurAbQE3dvQ
and theres plenty more!!!!!
