Which truck?
Which truck?
I want either a Losi XXL, Savage 5.9 XL or a Revo 3.3 . Which one will be the most fun but durable?
Ahh another one of these threads huh.
If you look at the top of this page, on that long blue bar that runs the width of the page. It is directly under the RCTech logo. inbetween New Posts and Quick Links there is a button that says Search with a yellow arrow point down.
Hit that button, And search!
Hi.
Xxl or xl. Both trucks have a lot of potential, I myself asked this same question a little over a year ago. I went with the xxl because I loved the layout of that truck,very clean and every thing is simple to get too.
I wasn't a fan of the xls layout to clustered but the truck is the sexier of the two. I do not own a savage but I will say this the xxl is very durable and it turns well. Think of it this way the xxl is a oversized truggy all you need to do is put some muggy rims on it and you got a truggy.
I will say this tho as a basher the savage is Probley the best out of the two all tho I haven't seen a xxl vs xl bash off so I wouldn't know. I will say this the xl will be my next buy very soon. All I can really say is if you get a chance to look at both of them side by side that Probley will help your desion.
Good luck and happy bidding.
I currently have a LST but its getting old and things are breaking more easily. I love it but I want something better. I think im going to go with the XXL but I heard that the diffs are a problem
I have heard when the xl came out having diff problem but I don't know if its true anymore. If you love your lst then all means get the xxl. It has all the new good stuff that made the lst2 kinda trouble sum. You won't regret the xxl or the xl.
Ok thanks. I think I will go with the XXL because I saw you can get some expensive diff gears that are TiNi or something like that. Are those any good or are they not worth buying
Dude personal I wouldn't wast money in that. The rear diffs are fine, of you plain on racing just get the foc change the diffs oils and maby different springs. As I said in my first post my diffs are a little over a year old and I'm just now having problems with them. Not because there old but because a shady hack job a local hobby shop did.
I will say this tho Probley every other month pull the diffs and check them just to be on the safe side because you have to remember that's a big truck with some power. All you need to do is take out maby 8 Allen screws and remove the tires and remove the hexes and then it will just pull out. This truck is the easiest truck to work on period.
So if you love your lst2 then by all means get the xxl you won't regret it,its well worth the $$$. The up grades I would do is some us know what you get.dynamite rear hub carriers front c hubs and front hub carriers. That's what I have on my xxl and its worth the $$.
One last thing make sure you also clean your berings inside your hubs. Happy hinting and let us know what you go with.
ok thanks for all the help. I was just worried because for some reason my diff case and bevel gear cracked when I took a jump in the back yard. I think it was because the wheels were spinning fast and they came to a dead stop when it landed.
Yea wot will definally break the diffs lol. If your a member of the losi fourm you should go that and look at my pics. I have a lot of pics on there of my xxl and the wreck it got into with a tree lol. My name is Doug e fresh on there. Just go to the mt and you'll see my name.
I have an aftershock and the lst xxl is basically a cross between the savage and the revo, the lst xxl has the durability of the savage and the handling of a revo so its perfect
If you didn't shim them yourselves in the proper fashion, then who did exactly?
