Need help with t-max 3.3 please
alright well im working on my buddys t-max 3.3 it was junk since the day he got it but i got it running now . and he told me that he took it to someone to fix and they took his reverse out when i start it and give it gas the spur gear and clutch both spin but the car doesnt move just revs up when i sping the spur counter clock wise it just spins freely when i spin it clock wise the tires move
it seems to me that the forward gear has been taken out not the reverse
not sure whats wrong any help would be good
thanks
thanks
Sounds like the one way bearing could be installed backwards inside the tranny. Might take a look in there and see if it can be flipped around.
Eric
Eric
thanks
thanks
thanks
thanks
if you are spinning the spur and the wheels are moving, it might not be the tranny. the spur might be slipping. tighten it down and check it before ripping the tranny open. check the clutch bell too, maybe the clutch isn't grabbing.
thanks
