which axle carriers?
im going to upgrade the front & rear axle carriers on my t-maxx 3.3. i was getting the rpm for the f & r, but i heard the balls on the arms pop out kinda easy because how rpm material flexes. so should i go with aluminum axle carriers, or stick with the rpm?
If the RPM material flexes, then unscrew the ball and put it back together.
I've never heard of or personally seen that happen on rpm carriers, I have them on my t-maxx and will soon have them on my embe, it those included larger size bearings that suck.
Aluminum down the center and on the corners is the strongest "set up" for a T-maxx IMO.
I use aluminum bulkheads with rpm stuff. I have stock carriers up front because they break before anything else. I can get 4 new ones for about 5-10 bucks on ebay.
At least you started from the center, that's the way to go on a maxx, most guys buy arms first and break stock bulks later.
LOL!!! Dude you have to unscrew the pivot balls!.....Rpm carriers come with oversize bearings too.
No you didn't!!!
