titan & larger shocks?
anyone know if the losi aftershock /lst1&2 shocks would work on a ofna titan and if any mods are need what needs to be done to do this?
I can't tell you for sure, but if you can get the clearance from your upper A-arms, then the large XXL shocks may fit. If you think the large shocks will clear the upper a-arm, I'll bust out my XXL, and measure out the shocks for ya, and give you some measurements to help you out.
To 'clear' the Upper Arm
1. Aluminum Shock Stand-Offs (8~10mm length)
(Like as any Buggy or Truggy use to mount their shocks to the shock tower)
2. Some additional Aluminum Spaces (May be 4~6mm length)
(RC shop have them)
3. Threaded-End Long Screws
(Long enough to go through the Shock Stand-Offs and the Spacers, and to your shock tower, and secure with a lock-nut at the end)
To 'clear' the Lower A-Arm
1. Aluminum Spacers
2. Full-Threaded Screws
(Long enough to go through the Spacers, and 'into' the lower arm)
You have to measure the 'clearance' you'll need and add what to 'space' them...
I mount those LST shocks to my Truckzilla Big Twin as mentioned above.
Hope it helps.
wow didnt relize someone posted here thanks for the info guys.
anyone know if the titan wheels will fit on a aftershock?
