MAMBA XL
DANG! That is almost as big as this Turnigy motor:
http://www.unitedhobbies.com/UNITEDH...ner_(eq:_70-55
Only 8640rpm max but I guess you could gear it up and up and up and up...
What would you use that for?? Boat??
Lol, close. This guy used three in his GO KART!!! http://www.youtube.com/watch?v=vwODx028_Jw
A guy at my hobby shop uses it in his giant airplane.
Suspended
wow...this maes me want to get a baja now!!!
HOLY ____! This esc/motor combo will be $650 bucks MSRP! Read here or down below:
http://www.bigsquidrc.com/mamba-xl-1...ss-conversion/
"Here’s some BIG news from Castle Creations. Pictured above is their new massive (about 3 pounds!) Mamba XL motor (bottom, obviously) motor. Along with the motor is a whole new beefy Mamba XL ESC that’s built to handle 8S LiPos and all the amp draw that’s going to pass through it. Not only that, Castle is releasing a complete conversion kit with machined metal pieces to make it all fit in your Baja 5B.
This thing is going to be ridiculous. The ESC is actually available now, the motor and conversion kit will be hitting in about 2 weeks. It’s not going to be cheap though. For the motor/ESC combo you’re looking at an MSRP of $650, while the conversion kit is retailing for $150. But that’s not all. There’s promise of a 10S capable version in the pipeline"
My 4S pack is already heavy enough, I just can't even imagine how much three 4S packs will weight when you put them together. That and the weight of the motor on these beast will make this a missile in disquise. Just waiting to see the first YouTube videos as this beast runs over someone.
The few converted Bajas I've seen documented in various forums, the elec is about 25lbs, the gas version is about 35lbs. In spite of the batt weight, its still lighter since you're loosing the engine. Thats still a lot of weight to have moving at 45mph. Course the nitro at 45 is also a lot of mass moving that fast.
I'm planning on converting my 5T since I rarely get to use it (noise, have to take it a long way to find a decent place to run), but I want to wait for the 12S version that Castle says will be behind this one.
2 months or so on the conversion kit.looking like January on everything else.
We decided to go with a Kershaw conversion kit and Leopard 1000kv motor with the Mamba XL esc. Leopard motors are good no matter what anyone says. The kershaw conversion kit is $129 The esc/motor combo are $419. Right there you have only $550 retail. Plus once the ESC is in after the 16th of December, you should be able to have a total conversion up and running before December is out.
