traxxas top fuel?
#16
I always used Cool Power 20%, but the oil content is what gives the added protection. The break-in period is when the most damage is caused on a motor, because the piston/sleeve is so tight.
#17
I'm familar with what's hapenning during breakin. I typically follow a heat cycling type procedure where I get temp up over 200F to allow expansion so there's no abnormal loads on rod, crankpin or anything else. I don't just idle an engine on a stand.
Thanks, I'll look for some Cool-Power to try on my next breakins.
#18
What do you guys thnk of Wildcat? I have been using it for some time because its a few buck cheaper than Odonnels at the lhs and they told me that Wildcat makes Odonnel. Im not sure if they are full of it or not, they sell both so why would they try to sell me the cheaper stuff?
#19
http://www.wildcatfuels.com/container.html
Thats Wildcats site and there's no mention of Odonnels, so either your lhs guy is misinformed or he's pulling your leg.
If you read the stuff on Wildcat Fuels, I can't see why there would be a prob. They don't do sponsorships and apparently that lets them sell their fuel cheaper. Cheaper doesn't mean its lower quality; looks like its the other way in this case.
TF is made by Powermaster and acknowledged on their site, so I don't see why Wildcat wouldn't acknowledge Odonnels if it were true.
#20
my opinion its garbage and wont run it again.
EDIT:
i run XP 33%. i used to traxxas because it was recommended but not anymore.
#21
TF is made by Powermaster and acknowledged on their site, so I don't see why Wildcat would acknowledge Odonnels if it were true.
#22
I run "Team Losi Nitrotane Race Gallon 30%" in my TMaxx.
It does just fine for me.
73 de Dave
#23
Im not sure about the other fuel brands but I have used Traxxas top fuel and Maxies, and felt they were about the same. I was told by several people that it was ok to switch between the brands, but that you should keep the percentage the same. IE.... if you use 20% stay with 20%
One thing that most of the time happens is that your glow-plug goes bad and have to replace it when you go up in nitro%.
PS Im gonna give Odonnels a try! I used WildCat fuel in my heli for over a year and had no complains about it; dont know about the car blend.
#24
Traxxas fuel is garbage. As one user said, way too oily. Makes your OWB slip really bad. Good tip if you're using it though and this happens, hold the rear of the car above the front and it will start then. Guessing the oil runs out of the bearings and allows it to grab the shaft.
Back in my nitro days, I ran Blue Thunder and loved it.
#25
#26
This is absolutely not true. For one thing your OWB should be packed full of synthetic oil, fuel should not even be a factor in your OWB. Those are roller bearings made to grab the shaft in one direction only. If fuel is compromising that area you should be replacing the starter shaft and backplate.
#27
Well friend it actually is true. I quit making up stories just to appear to know what I am talking about long ago.
I ran blue thunder, no issues at all and fired up perfect every time.
I ran Top Fuel and it SUCKED. This is MY OPINION and MY EXPERIENCE. People having different points of view and opinions are what make this country so great.
I have since realized nitro altogether sucks and don't have to worry about fuel at all so I'm happy.
#28
#29
#30
So how come mine is working fine after I cleaned then? Now you guys going back and forward of who's right and who's wrong, make think what caused then? Because I just know that mine was slipping and now its not.
