E-maxx Wheels
#16
Go to prolineracing.com or towerhobbies.com And look for 14mm wheels. Just do that. Dont go buy an adapter or anything just get the right size wheels. Im not sure why these other guys were telling you to get a 17mm adapter. Your fine with the stock 14mm and thats the size rims you should get
#17
The hub size is the size that fits on to your axle (trying to avoid saying your nut size, lol)
If it says 14mm 3.8 inch wheel then you find the tires that are 3.8 inches
Do NOT buy 40 series wheels UNLESS you have the 17mm adapter, then in that case you would also have to buy 40 series tires. But this is not your case
Also, If you are looking to buy BEADLOCK wheels (the tires are held on by many tiny screws) you must buy BEADLOCK tires (also in your 14mm).
#18
If you just refer to it as a 14mm hex or 17mm hex, its pretty clear what you're talking about.....
I know its more expensive, but you can change wheels too - as long as they're 14mm hex, they will work.
I wanted lightest weight wheels/tires to reduce rotating weight and get the most reponse from the motors. Reason I went with SportTraxx wheels and tires. That dropped a bunch of weight off of my 3906, making it much more responsive.
#19
http://www.traxxas.com/products/elec...ccessories.htm
It's best to change wheels and tires, you can use MT size (3.2) or stretch some MT tires onto LPR rims(3.7) for a lower profile.
Stock Emaxx wheels are similar to 40 series I think.(3.8?)
#20
Traxxas tires have a different bead so you can only use them with TRX wheels. Then you're limited with these rims:
#21
Is there a size tire and wheel that most people would switch to? The stock ones seem to work real well. Just wanted to go for a different look.
#22
Look for tires in the gallery: http://monster.traxxas.com/showthread.php?t=210087
I'd go with MT size or 17mm JConcepts Rulux Half-ups offset wheels and tires of your choice (Masher or Badlands)
#24
Anybody see a problem with this combo?
http://www3.towerhobbies.com/cgi-bin...?&I=LXJG97&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXVBZ9&P=7
or maybe these tires instead
http://www3.towerhobbies.com/cgi-bin...?&I=LXVS54&P=7
#25
http://www3.towerhobbies.com/cgi-bin...4971&search=Go
#26
#27
Thanks for the help guys. Any thoughts on mashers vs badlands? I'm mostly dirt, mud, and grass.
Also, are there any good reason to switch to 17mm? Hate to buy new wheels and then decide I want to switch to 17mm later.
